Blocking the bedsides.
Old Jan 6, 2020 | 02:41 PM
clintonvillian's Avatar
clintonvillian
How flat do you shoot for?
My new sides have about 1/8"-1/4" bows in them. Some of it was like that from the factory and some of it I have caused.
When you bolt the fenders on the bows pull out. So if you added filler you would end up with a bow the other way or cracked filler....
Old Jan 6, 2020 | 04:29 PM
Sickler1's Avatar
Sickler1
I would leave as is. My bedsides aren't to straight really either..unless your going for a show truck
Old Jan 6, 2020 | 05:38 PM
CharlieLed's Avatar
CharlieLed
When the fenders are installed they will pull the sides flat...assuming the fenders are true. The fenders cover a good portion of the bed sides so it's questionable just how much of that low spot will even be visible.
Old Jan 6, 2020 | 09:23 PM
52 Merc's Avatar
52 Merc
Like Charlie said, you'll need to bolt the fenders on and see how wavy they really are. If you pack the outside with bondo to fill that, you'll create two new problems. One, the inside will have the same wave and warble that you're trying to hide here, and it will show a lot more since you can see the whole inside, not just a little bit around the fender. And two, the heat from the filler will distort the panel even more, and you'll really struggle with doing anything with it.
mechanicblue3
17
Oct 21, 2024 10:12 AM
musicmanbiker
Nov 19, 2010 07:47 AM
teardropty
Sep 29, 2010 06:14 PM
Fighter-of-Wars
Oct 22, 2009 11:01 AM
sancochojoe
Jul 10, 2006 02:25 PM
