Cam recommendations 351W
Old Feb 13, 2020 | 08:01 PM
  #46
Conanski's Avatar
Conanski
Originally Posted by xlt4wd90
This is to try to maintain emissions compliance. I'm thinking of using the TFS stage 1 cam, TFS-51403001 (.499/.510 w/1.6, 221/225 @.05, 112 LSA), and tuning my A9L EEC with the Moates QH to handle this. I have some Cobra 1.7 rockers, so can bump the valve lift by about 6%.
I don't think that cam would pass a sniffer test, just a bit too much low lift duration which will negatively affect idle vacuum and make setting the idle mixture an impossible task, make it lean enough to pass emissions it will be stall prone, richen it up a bit and it will be more stable but it won't pass emissions. You may have to come up with a sniffer tune just for testing.
Would there be a better cam for a streetable engine that will not require too much tuning to achieve that and still make maximum use of the intake and heads?
Do you want maximum HP or a more street friendly curve?
Old Feb 14, 2020 | 01:04 AM
  #47
xlt4wd90's Avatar
xlt4wd90
I would like to get the maximum power from something that will still pass smog. So if the TFS stage doesn't do it, would you know what would be a better choice?
When you say "too much low lift duration", does this mean the lobes are really wide in the low lift areas? I guess it's hard to discern that from just the total and .05 durations.
Old Feb 17, 2020 | 06:29 PM
  #48
torq'ta 5 8's Avatar
torq'ta 5 8
going in your GT, not a truck?
Old Feb 17, 2020 | 06:45 PM
  #49
baddad457's Avatar
baddad457
Originally Posted by Conanski
That off the shelf cam is terrible IMO, it will totally strangle this motor.
Do you still have the stock roller cam? For reference this is what it looks like.
256/266 adv duration
198/208 @ 0.050" lift(not confirmed but a good guess)
0.422/0448" lift with 1.6 rockers
116 LSA.
This cam works great with a carb and with 1.7 rockers it's about as good as it gets for torque output, powerband is 0-4500rpm
Powerband moves up with better heads on a 302 with 1.7 rockers. I ran it in a ported E7 headed 5.0 and the powerband was from idle to 6 grand. With those heads I'd bet the power would go to 6500 on 1.7 rockers. Or if you can find one, use an HO roller, it'll give you a tad more power. Ford engineered the Cobra roller grind to get a cleaner idle (vs the HO grind) as I remember reading in their 5.0 HO book.
Old Feb 21, 2020 | 12:49 AM
  #50
xlt4wd90's Avatar
xlt4wd90
So is the stock HO cam your recommendation? (.445/.445 lift, 266/266 duration) for AFR 165 and GT40 intake combo on a 331? Or if I get lucky, a 93 Cobra cam (.479/.479 lift, 270/270 duration)?
Old Feb 21, 2020 | 06:54 AM
  #51
baddad457's Avatar
baddad457
Yea, if you want an emissions friendly cam, I'd opt for either the F4TE or the Cobra cam though to have the best chance of passing emissions. The HO makes more power though, the extra cubes would tame it somewhat, might be enough for emissions.
Old Feb 21, 2020 | 10:46 AM
  #52
xlt4wd90's Avatar
xlt4wd90
The HO makes more power than the Cobra cam, even though it has less lift and duration? How does that work?
According to Ford's specs, the 1993 HO engine made 205HP, while the Cobra made 230HP. I think I would want the Cobra cam, or something like it, for more power.
Old Feb 21, 2020 | 12:12 PM
  #53
baddad457's Avatar
baddad457
The Cobra had GT40 heads. This info came straight from Ford's HO 5.0 tech manual. They were going to use the HO cam in the Cobra motor, but decided to engineer the Cobra cam to get a cleaner idle.
Old Mar 1, 2020 | 03:43 AM
  #54
hairyboxnoogle's Avatar
hairyboxnoogle
The HO is a great cam, really, if a little anemic in the numbers department. The f4te cam is another really good one (slightly better) imo. End of the day theyre stock cams, i mean think about it (here comes the flame) the letter cams were better. Either one of the cams will be torquey off idle, but theyll fall off around 4500rpm. If you want a stock engine, put a stock cam in it. If emissions are concern, many of the "stage 1" offerings are smogable except for california. Probably the best cam around for "a bit more than stock" is the TFS stage 1, its a great all around cam, works really well with e7 heads.
Old Mar 1, 2020 | 08:50 AM
  #55
baddad457's Avatar
baddad457
Originally Posted by hairyboxnoogle
The HO is a great cam, really, if a little anemic in the numbers department. The f4te cam is another really good one (slightly better) imo. End of the day theyre stock cams, i mean think about it (here comes the flame) the letter cams were better. Either one of the cams will be torquey off idle, but theyll fall off around 4500rpm..
Try either with better heads and you'll find this isn't true. Just as running those TF cams with E7's, the powerband moves up. The specs seem anemic with the B cam, but I ran one with Canfield heads and a Vic Jr, the powerband ran from 3 grand to 7500 (run with 1.7 rockers on a 306)
Old Mar 1, 2020 | 01:16 PM
  #56
hairyboxnoogle
As i understand it hes running lightly worked E7s. Yes and no, youre still better off with matched parts. Canfields and victors are will in the performance area, heads that like to flow above where the stock cams even open. Meaning, they dont care about .100-.300" lift, theyre looking at .500-700" lift. My dad had a 440 with ported indy heads and a comparitively tame .680" lift 310 duration cam. Mismatched as hell? yes, worked great, also yes. Made for a unique combo that was hard to race against, most cars (in the pro bracket) dont pickup a lot of speed past the 1/8, the challenger did. Would make guy lift and hed blow by em on the top end. Only made 585 at the wheels, but was a fun 10.30 car.
Old Mar 1, 2020 | 07:12 PM
  #57
baddad457's Avatar
baddad457
"Matched parts" is hogwash. There's more than one way to get the powerband where you target it to. You can do it with heads, cam or intake. I ran the F4TE with home ported E7's ( opened the exhausts out on the walls and roof to match a Hedman gasket, then bowl blended them). Pretty much left the intake sides as is, aside from cleaning up the rough spots, then had a valve job done using a Serdi machine to do the seats. Power went from idle to 6 grand using a Ford A321 intake (same as the old Shelby Cobra part) Topped with a modified 1850 600, a 570 Street Avenger and a 3310 750. All three carbs did the same thing.
Old Mar 1, 2020 | 10:58 PM
  #58
hairyboxnoogle
Well by that logic, he should just bolt on some AFR 220s leave everything else stock and have a prostock engine
Old Mar 2, 2020 | 03:35 PM
  #59
baddad457's Avatar
baddad457
Sure you don't want to call that a Boss 302 ? There is an extreme end to some parts,(like putting those heads on a bone stock 72-76 302) but generally you can mix parts within reason to achieve the same goal. Or putting a Vic Jr on that too. The 220's valves may not play nice with the pistons on a stock short block.
Old Mar 2, 2020 | 07:36 PM
  #60
xlt4wd90's Avatar
xlt4wd90
Jacking the thread again. How about this cam:
https://www.edelbrock.com/rollin-thu...l-v8-3722.html
It claims to work with EFI, and even carries a CARB EO, so it must be emissions friendly.
Will it be too much of a choke for a 331 stroker with AFR 165 heads and ported GT40 intake?
