I have a 2015 that drives me nuts with it's regen and 'overlimit exhaust'
If I do a delete should I just take both the DPF/CAT off?
If I do that, do i need a muffler? I like the quiet.
Is there a pre made kit out there that would have what I need with just placing it? What tuner is recommended?
Will I need to delete the EGR? Or, can I just leave it?
You have to have a custom tune to delete it. Its best to delete the DPF, EGR, cat, and DEF system all at once. EBay still sells kits to do all of the deletes. If you have inspections where you live it may not pass.
