Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Speedometer?
Old Jan 5, 2020 | 10:54 PM
jmtbiggin's Avatar
jmtbiggin
Speedometer?
1960 f600. My speedometer needle is "bouncy'. Not the usual jump when shifting the 2 speed axle. Just a consistent bounce that had gotten worse. It make a little noise on cold mornings ad well. Does not want go faster than 35(ish) mph, even though truck is accelerating. I am thinking cable? Your thoughts?
FYI 292/ T98
Old Jan 5, 2020 | 11:00 PM
85e150's Avatar
85e150
Could be the cable. There is some kind of shifting block in the cable to change the speed for the two speed change. My dad's '58 (F600, 292/T98) was always sluggish and required a tap on the front of the speedo to shift sometimes. Finally it quit working. Since yours still works, a little poking around and cable lube might give you decades more service.
Old Jan 8, 2020 | 08:42 PM
Tenwheeler's Avatar
Tenwheeler
Binding cables often do that. If you have the gauge out you can rig up and run it with a drill. Be sure you are running it the correct direction. I thank 1000 RPM is 60 MPH. Do not run it to fast.
wavetrain75
Aug 7, 2019 10:41 AM
timrocker
Jun 26, 2007 09:56 PM
XLT79Ranger
Aug 13, 2002 10:15 PM
