Tremor Rake
Old Jan 9, 2020 | 05:54 PM
  #46
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
thanks for the info on this , i think next week , i am going to go the opposite and just do 1 1/2 block in front on our Tremor and add some 35 12.50 18 left over from our 6.2L truck . i like the wider foot print on our land. i dont mind the rear higher but the front seems about the same as others non lifted SD trucks. I measured 42 inches at front and 45 3/4 on rear stock . thanks again for posting info
Old Jan 11, 2020 | 05:31 PM
  #47
willynilly's Avatar
willynilly
will none of these tremors be offroaded ? lowering the rear 2.5" is a significant amount if you ask me
Old Jan 11, 2020 | 06:21 PM
  #48
Joe T's Avatar
Joe T
Why yall buying tremors and lowering the rear and even changing tires?
Old Jan 11, 2020 | 06:33 PM
  #49
Brian Exline's Avatar
Brian Exline
The rear is really high for a 35" tire. 3 choices.
Leave it.
Raise the front and go 37's.
Lower the rear 1-1.25".
Until I can get our 1200lb tongue weight camper hooked up to mine, I'm not doing anything. If it will be level or still have a bit of rake with the camper then I'm going to take 1-1.25" off the back end.
Old Jan 11, 2020 | 06:58 PM
  #50
mothnuts's Avatar
mothnuts
Originally Posted by Spaceman_Spiff
I appreciate the pics!! I was thinking maybe swapping in a 1- 1/2 spacer instead of no spacer.
I just did the 1 1/2” spacer on my ‘20 F250 and like it. 1” would probably have been perfect to me, as the 1 1/2” is only dropping it a 1/2”. Still makes a difference tho. I already had the 1 1/2” from my ‘19 that I traded in, so I just went with it. Now I’m debating on replacing the shocks.
Old Jan 11, 2020 | 07:02 PM
  #51
Spaceman_Spiff's Avatar
Spaceman_Spiff
that's good to know!! Maybe 1" is the way to go, I was thinking the extra 1/2" would help with squat. Did you change shackles?
Old Jan 11, 2020 | 07:06 PM
  #52
mothnuts's Avatar
mothnuts
I used the regular (no drop) Sulastic Shackles and the block with taper from PMF.
Old Jan 11, 2020 | 07:24 PM
  #53
Spaceman_Spiff
I forgot to ask u about the u bolts you used.
Old Jan 11, 2020 | 07:30 PM
  #54
mothnuts's Avatar
mothnuts
I reused the ones I got from PMF with the blocks.
Old Jan 11, 2020 | 07:37 PM
  #55
Spaceman_Spiff
Thank you!! Appreciate the help!
Old Jan 11, 2020 | 08:06 PM
  #56
ForCal's Avatar
ForCal
Even more than that, I think they have 3" blocks. Makes it around 2" lower than a stock 17-19, and lower than a stock 20.
Old Jan 23, 2020 | 12:14 PM
  #57
Spaceman_Spiff
So, I removed the 3" rear blocks and replaced them with the ORO 7/8" spacer. Seems to have leveled it perfectly for my tastes. Drove it around and have no driveline vibrations.
Old Mar 15, 2020 | 08:54 AM
  #58
Klutch5000's Avatar
Klutch5000
Did you use the 2.5 degree spacer or the 0 degree? Has it changed the ride at all?
Old Mar 15, 2020 | 09:02 AM
  #59
Spaceman_Spiff
I used the 2.5*. I have replaced the 7/8" with a 1.5", 2.5* from PMF. Gives me a 2-1/2" rake front to back. Looks better to me.
Old Mar 15, 2020 | 10:16 AM
  #60
Aliass24's Avatar
Aliass24
Any updated pics with the bigger block?
