Tremor Rake
Old Jan 5, 2020 | 11:33 AM
Joe T's Avatar
Joe T
Ready lift coils?
Then you loose the factory front plow springs.
ForCal's Avatar
ForCal
Originally Posted by No More Raptor
I will find the moldings and have them added.
My truck is scheduled to be here 1/13.
F350 CCSB Rapid Red Sport Ultimate.
Post up when you find some pricing and part#'s. I wouldn't expect paint to be more than a couple hundred, but Ford parts can be pricey.
Old Jan 5, 2020 | 12:08 PM
No More Raptor's Avatar
No More Raptor
Originally Posted by Joe T
Ready lift coils?
no coils..... ready lift 2.5 spacer.
Old Jan 5, 2020 | 09:03 PM
Brian Exline's Avatar
Brian Exline
I was surprised how much rake mine has tbo. I expected the tremors to only have a slight rake based on marketing info. I’m not offended by it but I am considering going the other way and lower the rear 1-1.5". It would still have some rake for when I tow but not quite so severe.
Old Jan 5, 2020 | 09:18 PM
Joe T's Avatar
Joe T
I think the 2019 350 rear blocks would drop it like an inch. The tremor sits up even higher than the 19 in the rear. It retains a lot of tow rating so thats why they didnt “level” it. To me the Tremor is more of a functional option for a work truck, they should offer HD springs on it too so you can put a heavier bumper up front.
Old Jan 5, 2020 | 09:23 PM
Joe T's Avatar
Joe T
Ah ok.
I think thats an upper spacer. Not a fan of those because of looks.
The reason I post this is because every picture I’ve seen of a 2019 vs 2020 front spring, the upper coil pad looks to be thicker on the 2020. May or may not work as advertised.
Been researching how they lift the Tremor because I may put some parts on my 2019. Thats all I’ve noticed so far, but they do it across the board on the superduty so your truck may come with those.
Old Jan 5, 2020 | 10:11 PM
ForCal's Avatar
ForCal
If you could snap a pic and measurement of the block that would be cool.
Old Jan 7, 2020 | 04:34 PM
Brian Exline
Sorry, been super busy. Measuring through the center line of the wheel, the front is 41 3/4" to the bottom of the wheel well. The rear is 45"
Old Jan 7, 2020 | 04:47 PM
RedRage's Avatar
RedRage
Just got done leveling my F350 6.7 Lariat Sport Tremor . I removed the rear blocks and installed 3" shorter U bolts. Front 41 3/4. Rear 42 1/8. Looks good to me that way.
Also, there is no vibration at any speed. Seems to ride just a hair smoother.
Old Jan 7, 2020 | 05:49 PM
Brian Exline
Nice. Would you mind posting a pick from the side and one from 1/4 off the rear by chance?
Where did you get your ubolts?
Old Jan 7, 2020 | 06:51 PM
RedRage's Avatar
RedRage
Sure
Sure but it might be a day or two before I have it out again. Had the ubolts bent up while I waited at Inland Truck Parts.
Or you can order the BC3Z-5705-K. Those are 3" shorter than the stock ubolts.
Old Jan 7, 2020 | 07:24 PM
ForCal's Avatar
ForCal
Thank you. That block is the same size as my 19, but you are sitting 1/2" higher up front, and 3/4" higher in the rear based on those measurements.
I'm stock with, stock tires. So, if that truck had the same size tires as mine, it would be exactly the same height up front, and only 1/4" higher out back. I believe Tremor requires high capacity tow package, making it have more leaves in the rear and probably contributes to some added height. This is all assuming we are measuring to the same points.
Old Jan 7, 2020 | 08:51 PM
  #28
Spaceman_Spiff's Avatar
Spaceman_Spiff
No, I had to add the high capacity to my Tremor. It does not come with it. Just an FYI.
Old Jan 7, 2020 | 08:54 PM
  #29
ForCal's Avatar
ForCal
Thats why I said "requires" and not included. It's a required option to get the Tremor package.
Old Jan 7, 2020 | 08:56 PM
  #30
Spaceman_Spiff
What I mean is, I could've ordered my Tremor without it. Not required.
