Forscan
#76
So, if I want to change to Bambi mode or say the 5 flash blinker lane change I need to get a laptop?
If I change the battery do I need to tell the truck there is a new battery in there? I've heard yes and I've heard no. Heard the truck will still treet the battery as if its 5 years old even though its new and holds a better charge.
We changed the battery a couple weeks ago, and did not do anything special.
#77
The following users liked this post:
#80
Knew nothing about battery reset and BMS stuff .... having trouble since.
Just got Forscan last couple weeks and trying to get an understanding.
Thanks for reply.
#81
Try disconnecting you battery for at least 8 hours first, both pos and neg terminals. Once you do that, tun the headlight switch on and leave it on to remove any residual voltage. Doing so will reset the BMS. Then, since the battery is disconnected, take it back to Auto Zone and have it load tested.
#82
Volts before disconnecting showed 12.37 ... after 12.48.
I've read somewhere, may have been this forum ... should change the battery type with Forscan. ( beings I did not replace with same type )
Any advice or experience with that ?
#84
There is a much easier way to reset the BMS and it takes a LOT less time. Here ya go:Procedure must be carried out within 10 seconds:
1. Switch ignition on (don't start)
2. Pull and release high beam 5 times
3. Press and release brake pedal 3 times
4. If successful the battery light will flash 3 times within the next 15 seconds
5. BMS reset completed
The following 4 users liked this post by COFLHTK:
#88
Turn on Ford Pass Connectivity with Forscan?
I'm pretty new to this and have looked and haven't been able to find anything about turning on the connectivity for Ford Pass with Forscan and was wondering if that was an option. I have an '18 F150 STX. Also struggling with getting remote start going. Got it turn on in the dash and have tried lock, unlock, lock and also lock, lock, lock without it working. More interested in the Ford Pass part but at this point either would be helpful. Thanks for your help!
#89
#90
When I did that it says my pickup does not have connectivity. I'm wondering if it is something that needs turned on or maybe I don't have the parts needed for it.
