Cab swap
Old Jan 4, 2020 | 08:54 PM
Sincer_boxxx's Avatar
Sincer_boxxx
Cab swap
Hi all, I have an early 99 powerstroke super cab short bed 4x4 that I rolled. The engine, trans, and running gear are fine but literally every body panel on the truck is toast, especially the cab. How involved would it be to put an obs single cab and a long bed on my frame be? I'm a welder and can probably gain access to a lift, I'm just wondering if this process has been done, if it will even be close to fitting, and/or even worth doing. Thank you for any and all input and info.
Old Jan 5, 2020 | 07:22 AM
Dan V's Avatar
Dan V
Could it be done? Well I guess. The far simpler thing would be find a 1999 thru 2007 cab.
Old Jan 5, 2020 | 08:31 AM
Sincer_boxxx
I realize that, but I could get an obs truck for cheaper than a super duty. Otherwise I'd do that, I'm just wondering if its worth the hassle to save some money or not.
Old Jan 5, 2020 | 10:55 AM
Dan V's Avatar
Dan V
Not worth it for me. I couldn't imagine the time it would take to make it work. But, your mileage may vary.
Old Jan 5, 2020 | 11:20 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You have to consider everything that, not just the cab to frame mounts. Things like pass through for the wiring harness, heater core, PCM mounting, steering linkage, everything... In my humble opinion if you want an older cab, you should go with a Highboy body conversion, or maybe a 1960's cab conversion or just go with a 99-07 cab and call it done. Just because you can get something cheap does not mean it is the right call.
Just my opinion...
SLUF681
Large Truck
Sep 11, 2019 02:53 PM
grobinsonpa
Mar 17, 2017 11:26 AM
Rentaro
Jun 4, 2014 12:07 PM
hpcma1
Jan 14, 2012 11:58 PM
BuddyB
May 29, 2009 09:21 PM
