changes to 2020 6.7 PSD
6.7L Power Stroke® Diesel 3rd Generation Engine Build Features and Facts
- Fuel
- New, higher pressure (2,482 BAR, 36,000 PSI) fuel injection system (2019 was 2,068 bar, 30,000 psi)
- This 20% increase in injection pressure increases fuel atomization for more complete burn
- A more complete burn increases fuel economy, and reduces emissions
- Updated high pressure fuel pump to produce increase in common rail pressure
- New fuel rails and lines to support more pressure and flow than ever before
- New piezo fuel injectors capable of injecting up to 8 times per single power stroke
- New fuel spray pattern built into the injector tips
- Pistons
- New 1 piece forged steel pistons to withstand higher combustion pressures with less friction
- Openings cut into steel piston skirts to reduce weight to match mass of aluminum piston of prior year
- Smaller wrist pin used to support the piston
- New low tension piston rings (lowest tension in the segment) to reduce friction against cylinder walls
- Piston rings fitted in tighter (closer tolerance) ring lands on the new steel piston
- New split stream piston cooling jets shoot oil simultaneously at the underside of the piston crown and the wrist pin
- Highest concentration of heat found in the underside of the crown of the piston, but high friction at the pin
- Rods
- New connecting rods (longer, to make up for shorter pistons, and stronger, to withstand higher pressure)
- New connecting rod bearings (still investigating if IROX polymer coated or if different nitrided coating used, such as Ion Plasma)
- Turbo
- New, smaller frame, Honeywell turbocharger with lower inertia, for faster response
- New turbine wheel
- New compressor wheel
- New dual axis variable vane precision support mechanics to support tighter clearances without wear
- Redesigned vane kit supports vanes on both sides of the plates, instead of just a guide slot on one side
- Prior version (2019 and earlier, to 2015) vanes were pinned on only one side, with one axle
- Double axle turbo vanes allowed to run closer to the housing, which improves efficiency and performance
- The closer the vanes ride the wall of the housing, the less internal air leakage, and the more flow efficiency
- New 100% electrically actuated, electrically driven variable vane geometry controller with 4 bar linkage
- Prior year vane geometry controller was electro-hydraulic, where the hydraulic actuation is slow to respond in very cold weather
- Fully electronic actuator is more responsive in cold weather, thereby increasing turbo response by reducing lag time
- Engine core
- New engine block, with structural enhancements
- New cylinder head casting, revising cooling passages and enhancing strength.
- New front cover
- New low pressure oil system pump changed from gerator type to gear driven type, size increased
- Intake
- New intake manifold, now a two piece design
- Material swaps... what used to be composite is now cast aluminum, and what used to be cast aluminum is now composite
- Lower intake manifold (non pressurized) is composite plastic to insulate better and reduce weight, as it operates in a cooler environment
- Upper intake manifold (pressurized) is now aluminum to provide heat protection since it rides over top of the turbo, in a much hotter immediate environment
- Other changes
- Crankcase ventilation filter and oil separator housing is now composite plastic (this housing was cast aluminum in prior year)
- Service interval for crankcase filters changed (interval difference unspecified... still investigating)
- New larger oil cooler / oil cooler the same (equally empowered sources at Ford reported conflicting information on the oil cooler)
- What didn't change
- EGR cooler cooler carries over unchanged (revisions were made in 2nd gen)
- New turbo still maintains all of the exhaust braking functionality as previous turbo
- Entire engine upgrade package was weight neutral... no change in weight, despite 25 more HP and 115 more ft lbs of TQ
- Industry Diesel Oil Standard remains as the older CJ-4, not CK-4. Ford recommends using Ford's proprietary oil specification.
See more (powertrain only so far) information about the new 2020 Ford Super Duty here: https://www.ford-trucks.com/forums/1...different.html
- Fuel
- Pistons
- Rods
- Turbo
- New turbine wheel
- Engine core
- New front cover
- Intake
- Other changes
Not sure it truly bullet proofs the fuel system but tries to circumvent parts of the fuel system to avoid metal in the various parts/injectors/etc and provide lubrication to the HPFP.
https://dockets.justia.com/docket/ca...cv06967/334859
https://www.carcomplaints.com/news/2...-lawsuit.shtml
Edit: The one in Texas I am thinking of is the GM lawsuit which appears to include Ford.
https://www.hbsslaw.com/cases/ford-c...on-pump-defect
