Transfer case
Old Dec 31, 2019 | 05:08 PM
DeeDubz's Avatar
DeeDubz
Transfer case
What fluid does ford recommend for transfer case on a 2011 f250? Anyone know the capacity?
Old Dec 31, 2019 | 05:13 PM
jav_eee's Avatar
jav_eee
Only thing I can recommend is to make sure you can get your full plug off BEFORE you take the drain plug out.
Old Dec 31, 2019 | 05:14 PM
Overkill2's Avatar
Overkill2
It used to be the Motorcraft XL12 transfer case fluid but I'm thinking they phased that out. You could probably still get it though. I think Mercon LV is what is used now I believe. Not a 100% percent though on that.
Old Dec 31, 2019 | 07:13 PM
senix's Avatar
senix
just did mine XL12 is what was used.
Old Dec 31, 2019 | 07:46 PM
HRTKD's Avatar
HRTKD
I'll be using whatever synthetic ATF fluid I have on the shelf, which happens to be a leftover case of AMSOil. As long as it's a suitable substitute for Mercon LV it will work.
Old Dec 31, 2019 | 09:17 PM
Overkill2's Avatar
Overkill2
I used XL12 when I did mine at 31k. I'm at 52k plus now. I have plans to do it again at 60k miles. We'll see if the dealer still has it in the spring then. I'm curious what they'll say about it.
Old Jan 2, 2020 | 12:25 AM
Superdave71's Avatar
Superdave71
As I was at the dealer a couple weeks ago getting supplies for my 200k service, XL12 was discontinued being replaced by Mercon LV
Old Jan 2, 2020 | 08:42 AM
Overkill2's Avatar
Overkill2
Just called my dealer and confirmed the same. LV it is.
Old Jan 2, 2020 | 12:17 PM
Sport45's Avatar
Sport45
A little bit off topic since mine’s a 19, but it seems odd the owners manual calls for Motorcraft Transfer Case Fluid while the spec is Mercon LV ATF.
I’ll probably use Valvoline MaxLife whenever I change mine.
Old Jan 2, 2020 | 01:11 PM
Overkill2's Avatar
Overkill2
Back when your manual was printed, probably 2018, it was still the XL12.
Old Jan 2, 2020 | 02:29 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The owner's manual is correct on the fluid but wasn't proofread for the description.
Old Jan 2, 2020 | 05:32 PM
kper05's Avatar
kper05
Here is what I found on the capacity in the 2011 1st printing, pg 402.
Old Jan 2, 2020 | 05:39 PM
Overkill2's Avatar
Overkill2
When I did mine, the two quarts it calls for wasn't enough. I needed an additional amount, though not much, out of a 3rd quart. That was my experience.
Old Jan 2, 2020 | 05:45 PM
kper05's Avatar
kper05
It looks like the TC changed on the 2017+, does anyone know if Ford published something on the change interval/compatibility for MERCON LV in the gen 1 trucks?
Old Jan 2, 2020 | 06:55 PM
Overkill2's Avatar
Overkill2
Here's a previous thread on this very topic about XL12 and Mercon LV for transfer case.
https://www.ford-trucks.com/forums/1580218-mercon-lv-in-transfer-case-2.html
