Testing coolant.
Old Jan 4, 2020 | 12:48 PM
BAC38's Avatar
BAC38
Testing coolant.
Im not sure if this is a stupid ? Or not. Is there certain test strips for Diesels? I bought RADCHECK COOLANT Test strips. I got them from NAPA. And what kind of numbers should readings be?
Old Jan 4, 2020 | 01:25 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
depends on the Coolant you are using. I don't use the Radcheck, I use the Fleetguard strips or Accustrip
the instructions should be on the bottle https://www.radstrips.com/ <<== is that the same thing as RadCheck ??
Old Jan 4, 2020 | 08:45 PM
BAC38's Avatar
BAC38
Ya they were the wrong ones. The girl at Napa was not helpful at all. Any ways I teacked down some fleetguard ones. So what do these numbers tell ya. ImI not sure what im suposed to be at. I'm between .6-.9 scA and -20F 45%
Old Jan 4, 2020 | 10:21 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
with Fleetguard you want to be in the Normal range https://images-na.ssl-images-amazon....-IZak%2BcL.pdf
.6-.9 is Low
BTW here is the link to the other strips I use https://www.acustrip.com/sca.html
it has a Calculator that might help you.
Old Jan 5, 2020 | 02:04 PM
BAC38's Avatar
BAC38
Thank you, what kind of coolant do you use and addittive? And do yiu got a part ## for filter? And how much colant does it take. Im assuming I should do a flush. I'm doing my. I also received my Innova code reader lsst night. Thanks @lonewolf for the recommendation on that 1.
Old Jan 5, 2020 | 02:57 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
my 93 F250 holds about 30 Quarts, I use good old 50/50 Prestone Green Slime .. I use the DCA4 additive .. here is another Link Fleetguard DCA60L Supplemental Coolant Additive at DieselManor
What Filter .. IF you have a Water Filter installed it should have a part number on the old filter..
IF you are wanting to Install a Filter you can start here .... https://www.oilburners.net/articles/coolfilter1.html
sandyc
6.7L Power Stroke Diesel
Jun 10, 2011 10:24 PM
mfreeman
Feb 20, 2009 08:31 PM
TNT in Round Rock
27
Dec 11, 2006 01:48 AM
tuke
Sep 22, 2006 09:03 PM
BGFNRED
Feb 7, 2006 07:26 PM
