You do have a stabilizer as others have noted. It is the part that looks like a shock that goes from the frame to the draglink that connects the two front wheels. Also I have a 2011 and it looks to me like you have a lift on this truck. I'm not sure how big a lift you have, but your truck is a lot taller than mine.
Stock stabilizers are not flashy. They really blend in.
It looks to me like it does have front spacers on top of the coil. Mine has the same, I believe they call it a leveling kit. The rear looks like stock height blocks.
I was also wondering if he might have a leveling kit - there's not much rake, or so it appears
Yeah I think you are correct. After looking at tons of stuff I can't see any components that look like the parts in a lift. These tires would rub the back corners of the inner fenders at max turn radius when I got the truck, I trimmed em so they wouldn't. Now they only rub at near full turn
and hitting a bump. I don't want it any taller - it don't fit in garage now.. I ordered a stock replacement Bilstein stabilizer - we'll see if it makes a difference.
Anybody know what the circled part is? There were a couple U bolts without nuts stuck on this bar when I got truck. Not sure what this thing is....
That's just supposed to be a safety to keep the tie rod adjustment sleeve from spinning. Not necessary in truth, but might as well leave it
Copy that. Never seen one before. I went from a 2001 Dodge 1/2 ton 4x4 that I bought new to this truck this spring. Lots of different things on this one! I am very mechanically inclined, usually do all my own work, but now that I'm older and have RA, CTS, and other crap medically - I would rather ask questions first and do the job one time...
UPDATE: Got the Bilstein 5100 today and installed it in about 15 minutes. One nut, one bolt, beat hell out of it with pickle fork and 2lb hammer, re-assemble. Did not have a chance to drive it yet - but the Bilstein is a LOT beefier than the stock one that was on there. I expect it to be much better..
I installed a Carli high mount today with a full back country Level kit on 35s and the add a pack rear spring packs. CJC suggested doing the highmount only with the 35s, and i could add the low mount if i went to 37s in the future. I got the low mount dif cover already so i would just add the extra stabilizer in the future. It comes precharged with 200 psi of nitrogen. Carli says to purge it a little at a time if it has a slight left pull to it until it tracks normal. Mine did not pull at all on the drive home so I left it. I'll post my assessment of the whole lift after I get an alignment and put some mileage on it.
