I am working in a 7.3 NA in a 1989 F350 Crew Cab Dually with an Automatic Transmission.
My Problem is that the Pickup Pump(Mechanical Pump) is not Picking Up any Diesel. We put a New pump on the truck today, and it is still not picking up fuel. We hooked a Vacuum pump to the Fuel line that goes to the Fuel FIlter, and we could draw fuel up with it.
Anyone got any ideas as to what our problem might be?
Reason: To edit post.
a Faulty Select Valve can Restrict fuel Flow in both Supply and Return lines.. often pieces of the shower heads in the tanks can end up in the Select valve and cause issues.
when installing a Lift Pump I rotate the engine to TDC this puts the Cam lobe at the lowest point to install the pump, some folks have managed to get the lever above the Cam Lobe (Don't ask me how) but the lever on the pump needs to be below the Cam Lobe.
Using a Manual Vacuum Pump can Draw Fuel thru a partly clogged Valve where the Mechanical Lift pump Might not.
you could Test your newly installed Lift Pump by connecting a Line to the inlet into a bucket of Diesel... IF the problem is solved then you Know the issue is with Lines or the Select Valve.
Thank you for responding to my question and for also taking the time to give me the above detailed answer. I think my next step will be the inlet hose into the bucket of diesel.....
You can also slide a hose over the inlet, have someone crank it while you hold your finger over the hose and make sure the pump has suction. These mechanical pumps really pull alot of vacuum.
Just make sure it's in neutral and you're out of the way of anything.
it is possible to get a DUD pump.. I generally test them by Hand first before I waste time installing in the first place
I've never purchased a "DUD" pump nor even sold one in all the years I worked a parts counter, but it is possible as all parts are not made equal, and if this one is a "DUD", I will surely check everyone I buy in the future, well I'll probably checking them anyway from here out....
Thanks Again...
Reason: a 2 I
If you want to move your pump to the frame rail, you could install an electric fuel pump (like a facet duralift) instead of that mechanical lift pump. You'd need to put a block-off plate so you don't have a gaping hole in your crankcase, and you'd have to run some new fuel hose, but it's not that hard to do.
pros: no more cranking for bleeding the fuel. just flip a switch. also one less thing to have in your engine bay. also, one less thing attached to your cam. pre-filter is cleanable. easier to access for maintenance. makes fuel system troubleshooting 10000x easier.
cons: fuel supply doesn't match rpms, but if you make sure you get a good quality e-pump with gpm and good psi (4-7 or 7-9), that won't be a problem.
Thanks for the info, we considered going electric, because the folks I got the truck from had already purchased a new electric pump, but in the end we went with the OEM Design Mechanical.
I also just checked out IDI Online, and it appears that site is going to provide some good reading and information,,,
ya I haven't ever received a DUD either, but because they are a PIA to replace I want to be sure I only do it 1 time... I'm Lazy that way
Man it doesn't get much lazier than me, so I garontee ya, that in the future I will check all mechanical pumps before installing, regardless of what I am working on.
