lugnut torque
Old Oct 12, 2003 | 08:09 AM
haul_n_horses2's Avatar
haul_n_horses2
lugnut torque
Does anybody know the correct torque for the lugnuts? Could not find a value in the owner's manual and I do not want to warp any rotors. Thanx in advance.
Old Oct 12, 2003 | 11:04 AM
daveplot's Avatar
daveplot
My 2003-2004 Ford service DVD says 150lb-ft
http://www.davidplotts.com/ford/wheel-tire-removal.pdf
Old Oct 12, 2003 | 12:26 PM
haul_n_horses2
Thanx.
Old Oct 12, 2003 | 01:39 PM
CMCSL's Avatar
CMCSL
Great question...never thought about it much until I passed by this site http://mysite.verizon.net/romano.mic...Lug_Nut_Torque
Think I will check my F-150 and wife's Taurus. The Taurus had problems with rotors during warranty but dealer refused to repair claiming normal wear & tear. Mind you these are the same folks who double filled my engine oil on the F-150 for the first scheduled oil change. Took the truck back after leaving the shop and the tech. could not figure out why the truck was suddenly running rough.
Always check what you can after service and do your homework. Try calling the Ford Customer Relations Center @ 1 800 665 2006 there is a good chance they may be able to pull a spec on lug nut torque.
Old Oct 13, 2003 | 09:14 AM
buzzard's Avatar
buzzard
Torque depends on year model. If you have the 12mm studs, you'll need around 100 ft/lbs. If you have the 14 mm studs, it's around 150 ft/lbs. The 14 mm studs were used from 2000 to 2002 (at least, don't know about the '03's).
Old Oct 13, 2003 | 09:20 PM
Daddy4zack's Avatar
Daddy4zack
Buzzard is correct.
Old Oct 15, 2003 | 08:35 AM
re-engineered's Avatar
re-engineered
I have owned many fords and I think this is a commonly over looked point. I have a 98 and I torque the lugs to 100 ft# and have never experianced any problems. I have made note to this many years ago after replacing rotors in my escort 3 times in a year at a repair shop that did not torque the lugs. After I did it I am still on the same rotors, 100,000 + miles later.
plgebbia
Mar 3, 2023 01:34 PM
dcf4x4
Apr 29, 2010 11:15 AM
Zephyr
Nov 17, 2007 11:03 PM
rebocardo
All Things Towing
Sep 21, 2004 04:12 PM
JimCaudill
1997 - 2003 F150
Nov 24, 2002 01:59 PM
