Lugnut torque ??
Old Nov 17, 2007 | 06:38 PM
Zephyr's Avatar
Zephyr
Lugnut torque ??
My book says the lugnut torque on stock alum wheels with the 2 piece washer type lugnuts is 150lbs.
I put on new wheels with an acorn style lug nut & a friend at work is trying to tell me that I should not torque them to 150, only around 90.
I think it should still be 150, What do you all think??
Old Nov 17, 2007 | 06:53 PM
guzzle92's Avatar
guzzle92
Neither ... 165 ft/lbs
https://www.ford-trucks.com/forums/5...-for-f250.html
Old Nov 17, 2007 | 07:03 PM
Zephyr's Avatar
Zephyr
Cool thanks ,,,,,,,,,,,, guess I should know better than trust a cheeap Haynes book.
Old Nov 17, 2007 | 08:53 PM
ernesteugene's Avatar
ernesteugene
Originally Posted by guzzle92
1) That's an old spec. Ford sent a notice to all registered owners, Doc # F81A-17A083-GC, which changes the old 165 ft-lbs to 140-155 ft-lbs. 2) However, this new spec is for the stock flat washer type lug nuts, not for the acorn style lug nuts like I've got on my 5er. 3) My 5er spec is 95 ft-lbs, and if I were to torque those to 165 ft-lbs the acorn style lug nuts would probably crush the wheel and it would fail short order! There's too much stress concentration to torque acorn style lug nuts that tight, IMO!
Old Nov 17, 2007 | 09:46 PM
guzzle92's Avatar
guzzle92
Didn't read the original post correctly, now I see we are speaking of AFTERMARKET rims and the 165 ft/lbs would be too much for these acorn type of nuts. That much would probably end up cracking the rim over time.
I will stick to the 165 ft/lbs on the original washer type of lug nuts on my truck (using a drop of oil between the net and washer) since the newest shop manuals used by Ford dealers still spec 165 for loaded trucks; 155 otherwise.
Old Nov 17, 2007 | 10:59 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Either way, they require more torque than a Honda makes!
Old Nov 17, 2007 | 11:03 PM
yamaguy's Avatar
yamaguy
I am my own torque wrench!
plgebbia
Mar 3, 2023 01:34 PM
four-sixty-power
Apr 29, 2016 08:25 AM
macguy
6.7L Power Stroke Diesel
Jun 29, 2012 09:26 AM
dcf4x4
Apr 29, 2010 11:15 AM
JimCaudill
1997 - 2003 F150
Nov 24, 2002 01:59 PM
