Complete Electrical Loss???
Old Dec 31, 2019 | 09:09 AM
Jpegg01's Avatar
Jpegg01
My 1977 F150 4X4 died last night, son was driving. The electrical system is complete shutdown. The fuel pump works it is wired direct and if I jump starter solenoid it works but nothing else. He was driving is started back firing and died which I assume is due to loss of fire. I have no schematics or anything. Is there a main fuse for the truck or is it likely ignition switch?
Old Dec 31, 2019 | 10:24 AM
Jpegg01's Avatar
Jpegg01
Well, I found the issue. Bare spot in wire was shorting out against fender well.
Old Dec 31, 2019 | 10:32 AM
84espy's Avatar
84espy
That was fast. Well done
Old Dec 31, 2019 | 11:31 AM
1TonBasecamp's Avatar
1TonBasecamp
Was it the large Black w/yellow stripe wire from the starter relay/solenoid up along the firewall? Or was it one of the battery cables?
Paul
Old Dec 31, 2019 | 05:22 PM
Jpegg01's Avatar
Jpegg01
No it was smaller wire, however it looked as though it may have shorted to a bigger black wire as well a fire wall. I couldnt actually see any bare wire on the bigger one but the insulation had been compromised
Old Jan 1, 2020 | 01:50 PM
broktruk's Avatar
broktruk
May be a good time to consider using a relay for the fuel pump? No disrespect intended, Just thinking out-loud.
Old Jan 1, 2020 | 04:49 PM
Jpegg01's Avatar
Jpegg01
Nothing wrong with the fuel pump, also fuel pump is fused and wired direct so it had nothing to do with this particular issue.
yd29999
1983 - 2012 Ranger & B-Series
Jun 23, 2022 01:47 AM
Hank85713
Modular V10 (6.8l)
Jul 7, 2017 10:40 AM
firespike
Jun 8, 2009 08:59 PM
wporter4671
May 25, 2009 09:42 PM
78150
Aug 28, 2006 06:59 AM
