I have a 2016 Ford F-350 6.7 with 80,135 miles. At around 38K Ford replaced under warranty the DPF Filter .
Went out today to get an inspection sticker and Failed. Had a OBD Permanent Fault Code P24A0. I really don’t want to go to Ford and spend a ton of money on getting this fixed. What are my options?
Limited since you need a sticker, you'll have to get it in somewhere to troubleshoot. If you have a reputable diesel engine shop that works on Ford pickups (has IDS), that's an option I use. It could be a sensor issue such as EGT11-14. The PCM monitors EGT12 to confirm the DOC exit exhaust temps are high enough to complete an active regeneration and the difference (expected vs actual) cannot exceed 68°F. I think this code is temp too low. If this were my truck, I would drive it to operating temp, park at home, shutdown, clear the code (KOEO) and then command a stationary manual regeneration (in a safe, open and well ventilated area; things get really hot and loud). If that is successful (the soot gpl is burned down quite a bit) and the DTC returns, it would go to a shop where the techs have far more experience than what little I know.
What is your daily driving like? What are the ambient temps like this past week in your area? Any EGR cooler issues? Two DPFs (the entire unit is DOC/SCR/DPF) in 80k is not good, these are around $4,500 to replace.
Picking up my 2015 from the dealerr today, had the P24A0 code. Ended up being a bad injector, they replaced them all to the tune of $7500, which the 100K engine warranty paid for.
Injectors are on the list as one possible item to troubleshoot if I remember. It's interesting though if one or more injectors are causing that much of an issue, that there isn't also a DTC for the faulty injector(s).
The truck is running like a top. I pull a dump trailer with a S300 Bobcat on it with no problems. I do a lot of in town driving. There was a couple of times I didn’t let the truck go thru a whole regen. On the dash a light piped up telling me to drive. But I have done a couple of nice hour long drives on the highway and the truck did a full regen and it seemed to help. My truck is stock and I have a Edge CTS monitor in my truck. Tells me the percentage on the DPF and when it’s in a regen. I hope it is t anything crazy. I really do like the truck.
The truck goes through it’s normal regens. The % of soot was like 3% right now. I know that the CTS can do Manual regens that I have done before. I got this CTS to monitor the regens and the % of soot. I’m bring the truck to Ford to diagnose the fault code. I just hope it’s a faulty sensor and not the fuel injectors.
