I have been looking all over the net but unable to find what I need. I bought a 1993 F250 for a winter beater. going through cleaning up a few things. The owner before the guy I bought it off did some " Brake Work" Been fixing all that as I like my brakes to work. I think the lines off the master cylinder are backwards. Unable to find a this is how it goes. I thought the rear port goes to the front brakes, and the front port went to the rear brakes? The old cast units with the separate fluid chambers were pretty easy to tell. Now they both share the same so I am unsure. Hope someone can let me know before I bleed the system only to have to change lines and rebleed.
