EGR, needed or not
Old Dec 29, 2019 | 10:23 AM
Saxon's Avatar
Saxon
EGR, needed or not
While working on my truck, I pulled the EGR valve off. While inspecting the valve, noticed the place where the exhaust pipe connects is all corroded.
If that part of the valve is supposed to move up or down, this one could not because it is stuck in place from the corrsion.
So does this truck require a EGR valve or not?? 1989 F-150 300-6
Old Dec 29, 2019 | 01:03 PM
Kramercd's Avatar
Kramercd
The short answer is yes. In computer controlled applications it is difficult to remove. I assume you would have to reflash the computer to get the system to run correctly without it. I don't know much about your year range, may get better information in the bricknose section. But generally when you pull an emissions component the computer locks the timing down and goes into limp home mode. This drastically affects fuel economy. But like I said, I'm not familiar with your particular system.
Old Dec 29, 2019 | 02:37 PM
Saxon's Avatar
Saxon
Ok thanks,
What is the bricknose section?
Old Dec 29, 2019 | 02:43 PM
Kramercd's Avatar
Kramercd
My apologies, I was in the middle of something earlier when I responded. As far as emission systems go, this thread is what we have compiled so far, it's tailored for bullnoses(80-86), but it applies to most everything. https://www.ford-trucks.com/forums/1...l#post18618848 Here is the bricknose section(87-96) https://www.ford-trucks.com/forums/forum28/ It won't be engine specific, but those guys may have more information for you about dealing with your computer system.
Old Dec 29, 2019 | 03:02 PM
Saxon's Avatar
Saxon
Yes sir, thank you very much.
Nbabballer
Jan 13, 2018 06:05 PM
SShank42
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 6, 2005 05:27 PM
forddytube
Jan 5, 2003 08:30 PM
cypherja
1997 - 2003 F150
Sep 26, 2002 07:19 AM
