Tailgate led light strip issues
Old Dec 29, 2019 | 09:47 AM
Towster's Avatar
Towster
I wired a 2019 blacked out lariat sport package cre cab 4x4 with a 49 inch tailgate light, from recon truck lighting, has a two row led with scanning amber turns, and center is a 14 inch back up led, the bottom row is marked and brake, wired back up into riverside tail light, and brake tail turns into back of 7 way plug, works almost perfect, till I back up, thinks I have a trailer attached, and no back up warning or guide lines,, help if anyone can!!!
Old Dec 29, 2019 | 11:36 AM
Sljb4's Avatar
Sljb4
I don’t know for sure but have read many times about how sensitive the trailer wiring system is. I have no experience with tapping a wire in the trailer wire circuit other than I know that I would not do it.
Old Dec 29, 2019 | 12:05 PM
smokewagun's Avatar
smokewagun
You can’t wire into the trailer plug. The truck is too smart. You have to go to the tail light wiring. The control module senses the minor power draw and will think a trailer is connected. Your lucky your experience was as minor as it was. Sometimes, weird and freaky things happen like your lights are possessed.
Old Dec 29, 2019 | 01:11 PM
Towster's Avatar
Towster
Oh crap!! Lol well thank you, Recon products are awesome, minus no instructions!!!
Old Dec 29, 2019 | 01:19 PM
smokewagun's Avatar
smokewagun
I emailed Recon several times recently because I’m putting theirs on my 2019 Lariat F-150. I’m putting it on in the next day or so. I’ll let you know.
Old Dec 29, 2019 | 03:57 PM
NorEasterMA's Avatar
NorEasterMA
This is a super common, super well documented issue. "Phantom Trailer" or "ghost trailer" are terms used to describe it. Either tap into your tail lights on either side or use the T-Harness from Magnum MFG (the company that makes headache racks) which plugs in-line with the rear end harness and T's off to give you S/T/T/R and ground without cutting, splicing, or interfering with the truck's brain. Good luck!
Old Dec 29, 2019 | 05:59 PM
Towster's Avatar
Towster
Thank you!
Old Mar 17, 2021 | 01:55 PM
schmiw1's Avatar
schmiw1
schmiw1
Just curious if you found one of the options to work?
Old Mar 17, 2021 | 02:02 PM
Poncho450's Avatar
Poncho450
Yup. Had this happen in the past when I plugged a lighted hitch receiver cover into the 4 prong. Stood to reason once I thought about it for a minute.
Old Mar 17, 2021 | 02:06 PM
schmiw1's Avatar
schmiw1
Greybird
Great - So, wiring direct and into the stop-turn-BU lights works
Thanks
Old Nov 5, 2021 | 10:53 AM
Greg Klecan's Avatar
Greg Klecan
Anyone had any issues with a light bar throwing off the BLIS system?
pdarby
May 25, 2019 02:44 PM
Chase4R
Dec 1, 2017 08:12 AM
LiquidSteam
Jul 14, 2017 03:36 PM
crewzer
Mar 30, 2017 08:53 AM
v2addict
Jan 10, 2016 06:16 PM
