Sponsored by: Real Truck
Multiple alternators not charging
Old Dec 29, 2019 | 08:56 AM
Maxtanner1's Avatar
Maxtanner1
Hey all. 1999 F-350 powestroke 4x4 sngle alternator setup. Battery light came on this weekend, found alternator was putting out zero volts at the B+ terminal. Replaced with remanufactured NAPA and I was getting 3V at the B+ terminal on the alternator with the large battery lead disconnected but the 2 wire connector in place. Decided maybe a bad remanufactured so I exchanged for s new NAPA, same thing, tried a remanufactured motocraft, same thing. From what I understand these are internally regulated and I have 12V at both the smaller green and orange wire in the 2 pin connector. From what I understand is those wires power the alternator and as it runs I should have 13.-15 volts coming off the large B+ terminal on the back but I'm still getting around 3. NAPA dud say they're having a bad batch of replacement alternators but I would suspect after 3 replacements there's something else up. Any secrets? Tried clearing codes with SNAP on solus between alternators, still nothing.
Old Dec 29, 2019 | 12:48 PM
alloro's Avatar
alloro
Originally Posted by Maxtanner1
NAPA dude say they're having a bad batch of replacement alternators but I would suspect after 3 replacements there's something else up.
If he's telling you that there's a bad batch I would buy one from someone else. I once went through 4 starters from the same place. I got tired of changing them so I returned it and bought one elsewhere and never had another issue. However with that being said, even if the alternator isn't putting out, you should have battery voltage at the B+ terminal unless the 2 fusible links are blown.
Old Dec 30, 2019 | 08:23 AM
Fefanatic's Avatar
Fefanatic
So, are you testing them with the battery wire disconnected from the alternator?
Old Dec 30, 2019 | 12:39 PM
Maxtanner1's Avatar
Maxtanner1
Yes battery wire disconnected, still putting out about 3 volts. Cleaned and tightened ground and verified continuity to ground from alt case to battery negative, but just to be sure used a jumper cable to give alternator direct path to battery negative and still getting 3 volts
Old Dec 30, 2019 | 12:42 PM
Fefanatic's Avatar
Fefanatic
What voltage do you get when you connect the bat wire to the alternator?
Old Dec 30, 2019 | 02:45 PM
redford's Avatar
redford
FTE Leadership Emeritus
I've had similar experiences with parts. I learned to never assume that a new part is a good part.
Old Dec 30, 2019 | 03:29 PM
Maxtanner1's Avatar
Maxtanner1
Get about 3 volts. Had alt tested at napa and o'Reilly that passed it. Called a friend who's a service writer for ford and the tech told her to check the fuse links, but I'm getting power at the executor wires when running
Old Dec 31, 2019 | 12:59 PM
Fallon's Avatar
Fallon
Running an alternator without a battery attached is a great way to quickly blow up an alternator & the rest of your electrical system. Without the battery there to dampen voltage fluctuations you can get WAY more voltage than you should into your electrical system & fry things.
Larry Rawls
Jul 23, 2024 03:29 PM
KirstenxMarie
Nov 18, 2022 07:50 PM
fordtruck661
Aug 3, 2013 09:23 PM
Raider949
13
Dec 22, 2012 07:31 AM
highgearonly
Jan 30, 2006 07:58 AM
