Battery Drained Overnight
Old Jun 4, 2013 | 12:06 PM
fordtruck661's Avatar
fordtruck661
Hi guys went out to the truck this morning to a dead battery. The battery's were very dead. so I hooked them up to a charger and went back out to start and found a warm alternator......My be where my problem is. Should there be voltage going to the alternator when the truck is off?
Thanks
Old Jun 4, 2013 | 01:37 PM
Tugly's Avatar
Tugly
That depends. Unplug the connector on the alternator and check voltage on both small wires. Do you have 12V on both small wires? If yes, the ignition switch is highly suspect. If only one has 12V, the alternator may fall in line with the rest of us that have had recent alternator failures.
Old Jun 4, 2013 | 04:06 PM
fordtruck661
Just went and checked and only the Orange wire with the blue stripe has 12V
Old Jun 4, 2013 | 05:23 PM
Tugly's Avatar
Tugly
It doesn't look good for a warm alternator just sitting there. You can disconnect the big wire and hook the small connector back up. If you are familiar with how to measure current between that lifted big wire and the post it was connected to on the alternator, that would be the final test. Otherwise... you can take it someplace and have it tested.
Old Jun 4, 2013 | 09:03 PM
fordtruck661
Ok Im going to leave it overnight and see if its dead In the morning. If it is Ill start playing with it more. But Testing the battery's over several hours they seemed to stay right at 12.6V.
Old Aug 3, 2013 | 05:56 PM
fordtruck661
Ok well here I am again.......Had no problems till yesterday morning went to start the truck and they are back down to like 8V......What was the fix for the alternator draining? Replace it?
Old Aug 3, 2013 | 09:23 PM
landmobile's Avatar
landmobile
Ok well here I am again......What was the fix for the alternator draining? Replace it?
Yes, if the alternator is warm and the batteries are going dead the alternator probably has a shorted diode and it needs to be replaced.
KirstenxMarie
Nov 18, 2022 07:50 PM
revrjim
Apr 25, 2018 05:20 PM
fourbangerford
Electrical Systems/Wiring
Jan 8, 2014 05:51 AM
Raider949
13
Dec 22, 2012 07:31 AM
cornfeed
Feb 1, 2005 04:51 PM
