5R55E Issues
Old Dec 28, 2019 | 07:36 PM
jstiles's Avatar
jstiles
5R55E Issues
Having issues with the transmission in our 2005 4.0L Ranger FX4 at 199K mi. The trans whines in first gear and shifts a little harsh into second. Once it gets past second gear, it seems to run fine. Doesn't matter if the OD is on or off. I have had codes checked and found nothing pertaining to the trans, only 4wd indicator in high and low and a few ABS problems. The 4wd works fine though, as does the ABS. The fluid / filter were both changed about 30K miles ago and is at the proper level with no hint of burning. I would appreciate any info on the matter. Not looking forward to pulling another trans. Thank you in advance.
wheelchairdude49
1983 - 2012 Ranger & B-Series
36
Oct 15, 2015 09:02 AM
sekyridgerunner
Jul 16, 2014 07:27 PM
rickwhis
Sep 9, 2013 07:55 PM
Franko72
Aug 4, 2010 08:07 PM
