97 Ford expedition theft system problem
Old Dec 28, 2019 | 05:21 AM
Browns performance's Avatar
Browns performance
So this is definitely a different kind of problem. I bough my 97 Ford expedition with a 4.6 motor 4x4 about 7 years ago. Now since day one I've had one issue after another. Mainly shorts in the electrical. The other week I went out to a junk yard found a 1997 exspdition. Everything worked on it. So I began removing every part I needed. When done I reinstalled all the parts to my truck. Everything worked great. Then everything stopped. I mean everything. Got my tester out and it said the PCM wasn't working. So I pulled it out and ran the numbers. He's where it gets weird. It's a 1997 exspdition with a PCM for a 1999 exspdition. Lost and confused. I tracked down the first owner. He told me he lost all power got tired of looking for the cause of the problem. So he went to the junk yard and pulled steering column including the pats theft system and key and the pcm from a 99 exspdition. Different years. I didn't know this was possible. Said he didn't have to have anything reprogrammed. Just basically plug and play. Well knowing that I went back and started replacing new parts with old. Til I got the system working again. Figured since it had a 99 system in it instead of a 97. It couldn't read the 97 parts I installed. And sure enough that fixed it.now I've lost my keys. And the theft system activated. ive called every dealership and locksmith. Price between 300-400 to get me mobile. I I do can't afford that. So could I do what the first owner did. And go back to the junkyard and pull the steering column including the keys and PCM out of the same year make and model. put them in my truck and make it work. With out programming. I'm thinking it should work. As long as I get the steering column and PCM since they already talk to each other. And put them in my truck they should let me start it no issue.
​​​​​​New information found a parts exspdition it's a 2000 with a 5.4 motor would I be able to use the steering column theft system and PCM even though it has a 5.4 motor and mine has a 4.6
Old Dec 28, 2019 | 07:40 AM
Franklin2's Avatar
Franklin2
Never done, never used this program, but there is a software program called Forscan that gives you lots of power to look at the computer system and change things. It's free, but if you want to do the key part that you need, you have to pay a small fee. I think it's very small for a short time period. If you want lifetime rights to the more powerful key programming, I want to say it was $50. I have never used this program, don't know how difficult it is. Why don't you do a google search on it and see what comes up about it and your problem.
Here's a link to the site. I see they have their own forum also. https://forscan.org/home.html
chromiumh1
Jun 14, 2017 08:00 AM
gharmon
1997 - 2003 F150
Jun 6, 2015 10:00 PM
Mr.Dilac7.3
18
Jan 3, 2014 07:38 PM
chris86924
Oct 11, 2013 06:17 PM
snbird
1983 - 2012 Ranger & B-Series
May 14, 2003 09:04 AM
