Sponsored by: Auxito
Condensation on Windows inside
Old Dec 26, 2019 | 09:38 PM
Firemanfig's Avatar
Firemanfig
01 regular cab f150 xlt. For a few months now,every now and then, all the windows will get wet on inside of cab while in driveway overnight. I made sure all windows were closed completely. Anyone else have this weird problem or have an idea of what's going on?
Old Dec 26, 2019 | 11:56 PM
Bluegrass 7's Avatar
Bluegrass 7
Look for a leaking windshield.
Old Dec 27, 2019 | 08:43 AM
steve(ill)'s Avatar
steve(ill)
I would guess it has to do with the humidity in the air and the temp change overnight compared to the temp in the truck--- condensation
Old Dec 27, 2019 | 10:39 AM
alloro's Avatar
alloro
If you track snow inside on your shoes it will melt and raise the humidity level in the cabin.
Old Dec 27, 2019 | 02:13 PM
BassFantasizer's Avatar
BassFantasizer
There are quite a few ways to get that much moisture inside the cab.
You could be bringing it in with you (snow, rain, etc.).
Was coffee, water, soda, tea, etc. spilled in the cab?
How long did it sit? Moist can seep in and build up.
From inside the cab, check the top of the rear window for signs of moisture or staining. This a problem area especially if you have a sliding read window.
Speaking of sliding rear windows, check all around (and below) it for moisture or staining.
Check the floorboard under the glove box. The heater core could be leaking.
There are lots of ways for moisture to get in the cab. These are just a few.
Old Dec 27, 2019 | 10:10 PM
Firemanfig's Avatar
Firemanfig
Thanks. I do have sliding back window. Truck is a weekend driver,so it sits for periods. There is a great deal of wetness on all windows. I will check for leaks around rear window.
Old Dec 28, 2019 | 05:45 PM
pdqford's Avatar
pdqford
If your coolant level is down, you may have a leaking heater core. That will put moisture into the cab.
Old Dec 31, 2019 | 01:20 PM
truckguy92's Avatar
truckguy92
When I shampooed the seats in mine, I had condensation on the inside windows the next morning. Had you recently detailed the interior?
Old Jan 29, 2020 | 04:42 PM
Timothy Davis's Avatar
Timothy Davis
Lightbulb
I had the same problem, went to Lowes and bought a closet dehumidifier. Placed it under my seat with zero problems since. $5 fix for me.
Old Jan 29, 2020 | 08:00 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Sure, but if OP has either a front of rear leaking windshield/window, that’s not gonna help. The windshield leak usually drains down on the GEM module. Bad news.
That aside, the humidity from my leaks has been from the rear leaking. A new shot of butyl tape cures that. But, the whole creature has to be removed.
Old Feb 2, 2020 | 11:08 AM
alloro's Avatar
alloro
What about the 100 miles of extension cord you need to keep the dehumidifier plugged in while driving?
Frank79
Dec 11, 2019 11:59 AM
Truck Guy99
Oct 21, 2016 09:30 AM
scottie2hottie
Oct 27, 2006 10:08 PM
WillyB
39
Dec 27, 2005 01:21 AM
awaters
1997 - 2003 F150
24
Sep 4, 2003 08:21 PM
