Sponsored by: Auxito
4.2 harmonic balancer change
Old Feb 1, 2020 | 10:35 AM
Chris Wilson's Avatar
Chris Wilson
I see several posts about what needs done as far as tools but what I dont see is the parts list. I need to know if I have to change a timing cover seal and a crank seal? Or just a crank seal? I've never done one that had all this extra junk on it. The ones I've changed have been a simple pulley with a key way. It's like ford wanted you to do timing chains and the water pump when you did the crank pulley. Just crazy!
Old Feb 2, 2020 | 07:42 PM
z31freakify's Avatar
z31freakify
Just the timing cover seal since you are already there. I would suggest clraning all oil from the crank snout and key way and add sealant on the key way slot on the new harmonic balancer.
coletr2
Oct 23, 2015 07:54 PM
zwaechte
Sep 21, 2015 11:52 AM
theFear
Mar 23, 2010 07:24 AM
gtex
Sep 15, 2003 05:33 PM
Hawkeye58
Feb 21, 2002 10:39 PM
