Injector service.
Old Dec 26, 2019 | 12:47 PM
chayes01's Avatar
chayes01
Injector service.
I've had my 2000 7.3 for 10 years now and it has 224,000 miles on it and have not had any injector service since I've had it. I'm not having any problems with them but is there a service interval? I'm not thinking about replacing them as I have plenty of power for what I need after adding 4"SS exhaust, DP Tuner with tow codes and a new billet turbo compressor wheel. Spring is going to bring on camping season and I need to be ready. I have no current idea what my mpg's are as I've purchased a different travel trailer and haven't towed a significant distance since adding the new compressor wheel.
Old Dec 26, 2019 | 03:04 PM
Bonanza35's Avatar
Bonanza35
If there running fine leave them alone. Just run good diesel oil of your choice, in the engine.
Old Dec 26, 2019 | 03:16 PM
chayes01's Avatar
chayes01
Thanks, that's all I needed to know
Old Dec 26, 2019 | 03:29 PM
MoBill122's Avatar
MoBill122
Papa Smurf
I'm still running the originals in my 2001..... I did replace the oil rings though
Old Dec 26, 2019 | 10:59 PM
aklim's Avatar
aklim
Is it a bad thing to service? I have done it on a 99 E300 Turbodiesel. Around 100K. Picked up about 1 mpg. I service the injectors on my gas cars every 100K. There IS a flow difference in the before and after results as evidenced by the service facility. 20 or 30 cc, IIRC. I did it initially at 50K and then at 100K and see what sort of difference there is which helped me decide what the interval might be.
Old Dec 27, 2019 | 09:01 AM
Walleye Hunter's Avatar
Walleye Hunter
What got serviced?
Old Dec 27, 2019 | 09:02 AM
oharal's Avatar
oharal
If it ain't broke don't fix it. Granted there are lots of different ways for our injectors to start down the road of reduced performance since they are so....sophisticated. Poppet wear reduces armature clearance, injector o-rings start to fail causing oil to mix into the fuel which makes your HPOP work harder to hold commanded pressure, injector hold down bolts loosen up making loud noises...if you don't have one of the telltale signs I'd say run em until you do. I'll be fixing my armature clearance and hot torquing my hold down bolts sometime in January. I might need to do the o-rings too but I I'm going to hold off on that right now.
Old Dec 27, 2019 | 10:05 AM
aklim's Avatar
aklim
Originally Posted by Walleye Hunter
What got serviced?
https://fuelinjectorconnection.com/c...-iroc-firebird
  • 1) Injectors are externally cleaned, visually inspected
  • 2) We test injectors for resistance, shorts, and current draw.
  • 3) We perform a leak test, spray pattern, and flow rate testing on one of our 3 ASNU flow benches. All data is recorded and sent to you.
  • 4) Remove filter baskets, o-rings, and pintle caps. Metal injectors are bead blasted to remove old paint and rust from the injector body.
  • 5) The injectors are placed in a heated ultrasonic bath to insure that the injector is free of dirt and contamenants that could hinder the rest of the process.
  • 6) The injectors are now put into another ultrasonic system while they are pulsed allowing the ultrasonic energy to dislodge any particles and build-up inside the injectors.
  • 7) The injectors are now back flowed to remove all debris, etc.
  • 8) The injectors are now returned to the flow bench for retesting of all functions. The data from this test is INCLUDED in detail with your injectors.
  • 9) The injectors are now refinished with high temp paint. the stainless steel injectors are polished to a high finish.
  • 10) One of our techs. now reassembles the injector, using all new parts.
  • 11) The injectors are then vac sealed and packaged for shipment
Old Dec 27, 2019 | 10:06 AM
aklim's Avatar
aklim
With my W210 diesel, I gained 1-1.5 mpg. Would you consider that "broke"? I would and it paid for itself.
Old Dec 27, 2019 | 01:44 PM
Bonanza35's Avatar
Bonanza35
That's more of a rebuild then a service. If you want to do this then go for it. Rebuild every 100K, sure you might see some improvement, at least you did. Then it all depends on who does it to.
Old Dec 27, 2019 | 01:50 PM
aklim's Avatar
aklim
If you have access to a testing facility, it is good to see what happens. I checked what I was getting before I sent it out and checked it after. That way I can see what he says is wrong or right so he doesn't just print off a bunch of self serving numbers.
Old Dec 27, 2019 | 01:56 PM
Bonanza35's Avatar
Bonanza35
You know I just went to his site, that is gas injectors? You say you send your diesel to? They have to come a part to do what he says he does. In that case, just send them off to be rebuilt every 100K. Not trying to argue, just saying.
Old Dec 27, 2019 | 02:04 PM
aklim's Avatar
aklim
I send them my gas injectors and last few times, I sent the diesel ones to Diesel Forward. They will test them and clean and replace the O-rings or gaskets as needed. If they are FUBAR, you might have to pay to get a new one.
mta5002414
31
Dec 15, 2019 11:58 AM
MTP55
May 6, 2019 12:24 PM
cabloom300
24
Aug 19, 2014 08:05 AM
cork13
13
Mar 16, 2014 04:28 PM
jwillson4
Jul 28, 2003 01:20 PM
