Question on torque pro PIDS
Old Dec 24, 2019 | 03:04 PM
jstihl's Avatar
jstihl
I just got a bafx bluetooth obd11 dongle and downloaded the torque pro app. My question is why cant I read any of the important PIDS? wanted to see what ebp , map, and several others . The only ones that are available are highlighted in green and unfortunately most of the pids I am trying to view are not available. Also my coolant temperature is reading -40 Celsius? Am I doing something wrong here? I just figured I would be able to view the common pids , but that doesn't seem to be the case
Old Dec 24, 2019 | 03:30 PM
Hootr's Avatar
Hootr
Did you set up the predefined set for Ford? Go into settings, manage extra PID/Sensors, press the 3 dots top right corner and select add predefined set, select Ford (include powerstroke).
Old Dec 24, 2019 | 03:57 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If you have a 4R100 truck, you cannot read coolant temperature. If you have a ZF6 truck, you can read coolant temperature. Most 4R100 drivers read EOT instead and that gives them a good idea of what the coolant temperature is at.
You need to load the pre-defined Powerstroke PID list.
Go to 11:00 in this video...
Old Dec 24, 2019 | 04:04 PM
AllaboutMPG's Avatar
AllaboutMPG
Not doing anything wrong just having to figure it out like most of us.
Like Sous said automatic tranny trucks don't send coolant temp to the computer. The sender on our trucks is basically a resistor that feeds the dash directly so you can't see it through OBDII
Old Dec 24, 2019 | 06:15 PM
jstihl's Avatar
jstihl
Thank you guys for the input, I will look for ford specific pids, not sure why I couldn't find this earlier because I had torque pro set up for a different truck years ago. Thanks again , I appreciate it
Bohen
6.7L Power Stroke Diesel
Aug 16, 2017 09:44 AM
Mcrafty1
Jul 10, 2015 07:29 AM
krazy_horse
Feb 21, 2015 04:44 PM
06F350PSDDually
Dec 20, 2011 07:09 PM
ford390gashog
Jun 4, 2004 09:56 PM
