Sponsored by: Real Truck
Draglink Castle Nut Stuck!
Old Dec 24, 2019 | 09:47 AM
Some Ford Guy's Avatar
Some Ford Guy
4wd Low
Exclamation Draglink Castle Nut Stuck!
Merry Christmas Eve, everyone!
I'm attempting to remove the draglink on my 02' 7.3 4WD, and I've hit a bit of a snag. The castle nut holding the draglink to the tierod end on the passenger wheel will not come off. I've removed the cotter pin, and when I put a wrench to it, the bolt and nut spin as one. I can't get enough torque on the castle nut to break it loose without the bolt spinning, and the space is too tight to get my impact gun on it. I've got it soaking in PB blaster and I've tried turning the steering wheel to put tension on the joint. Any thoughts?
Old Dec 24, 2019 | 10:55 AM
sxrfun's Avatar
sxrfun
I take it you're replacing tie rod ends and drag links etc? You can heat the nut up to help break it free. You can also place a floor jack under the tie rod end....jack it up a little to put pressure on the tapered bolt/joint bolt of the tie rod. This will help hold the bolt in place hopefully.
Old Dec 24, 2019 | 11:19 AM
jsukey's Avatar
jsukey
X’s 2 on adding some heat to it and everything else that sxrfun mentioned. Try whacking it with a BFH a couple of times immediately after you heat it as well. Just don’t hit it and mess up the threads.
Old Dec 24, 2019 | 11:53 AM
WWR's Avatar
WWR
After the above it's nut splitter then cutting wheel in that order, IMO
Old Dec 24, 2019 | 10:46 PM
Colorado350's Avatar
Colorado350
Welcome to FTE.
Do you have an impact wrench? Definitely worth the investment, Dewalt 20V, Milwaukee etc. Using a jack can work, put a box wrench on it first then the jack, smacking the wrench may be enough to break it loose...
Old Dec 25, 2019 | 09:49 AM
Fefanatic's Avatar
Fefanatic
If it's spinning on the tapered end where it goes into the knuckle then it needs to be replaced anyway. Once you have it loose and out check the knuckle for any excessive wear or distortion. That drag link end should fit tightly in the tapered socket and not turn. If it does you can have serious problems down the road.
DHenderson52496
1997 - 2003 F150
Feb 12, 2019 01:18 PM
Ira Brown
Jul 5, 2010 08:54 PM
mac_91
1978 - 1996 Big Bronco
Jun 11, 2009 05:09 PM
BADAS03SVT
Jun 29, 2008 09:18 PM
FutureFordOwner8
Mar 9, 2006 07:31 PM
