Battery drain
Old Dec 24, 2019 | 12:45 AM
3454terryg's Avatar
3454terryg
Battery drain
2000 Excursion 7.3 diesel Drains new batteries in three days. with both neg posts hooked up, when you put on the first positive cable to the positive post, without the other positive hooked up, i get a pretty sharp spark. then when you hook up the second battery, no spark. unhooked all fuses and relays one by one and still arced the same. unhooked the starter then alternator and got the spark when touching the first positive cable to positive post. Obviously there is a significant draw. How do I find it? Any ideas? thanks
Old Dec 24, 2019 | 02:47 AM
seville009's Avatar
seville009
Many many threads....here’s one that hopefully helps
https://www.ford-trucks.com/forums/1...ery-drain.html
good luck; always a pain to find the culprit
Old Dec 24, 2019 | 09:50 AM
3454terryg's Avatar
3454terryg
thanks i will look
Twais
Apr 16, 2019 06:06 PM
ExtraDry
Jan 4, 2017 07:03 PM
Lost Yankee
Dec 27, 2014 05:28 PM
Berserk
May 4, 2006 05:17 AM
maa139
General Automotive Discussion
Aug 27, 2004 05:20 PM
