I have 2011 F 350 SD that will be going away when new truck arrives. I found a site stating I have 8 X 170mm currently. It also showed the 2020 SD have the same.
Can anyone verify. Thinking about keeping my set of after market wheels and let dealer have the stock wheels.
Thanks in advance.
I think the only problem you could run into is that if your new truck has the larger rear axle the hub might be too large to fit through the hole in the wheel.
My 2019 F350 SRW has a bigger rear hub centering the wheel than my 2008 F350 SRW did.
Both had 8x170mm wheel bolt patterns tho.
The Front Hubs were the same on both trucks.
This wouldn’t matter on aftermarket non hub centric wheels using tapered acorn lug nuts.
Thanks for the answers. I may hang on to them to see if they work. If not I could always sell.
The tires that are on them only have about 10000 miles and hate to just give away.
