Sponsored by: Real Truck
Need to know
Old Dec 22, 2019 | 12:09 AM
Gary Liggins's Avatar
Gary Liggins
Need to know
I have a 2015 extended cab, I need to know if an 2006 door will fit my truck.. anyone?
Old Dec 22, 2019 | 08:54 AM
seville009's Avatar
seville009
Can’t answer your question, but usually if you go to a vendor’s website, they will match parts to your vehicle, so just look for the door you want and see if you get the same result for both years
Old Dec 22, 2019 | 11:08 AM
Fefanatic's Avatar
Fefanatic
car-parts.com You can enter your vin and then look for the parts. Most vendors show the years their parts came from and you can determine from there. FWIW, I doubt a 06 door will work but you never know...
Old Dec 22, 2019 | 04:08 PM
Just Strokin's Avatar
Just Strokin
Appears the outer skin is the same but the door shell is not. Why it is not the same might be some hole differences for mounting items.
https://parts.autonationfordwhitebea...and-components
Old Dec 23, 2019 | 04:33 AM
Jacsent1's Avatar
Jacsent1
the difference is in how the window lift mounts into frame. It is able to be worked around with a drill and grinder to open up a slot in upper inner frame rail.(you’ll see difference when you have both door panels off).... or if you plan to use all the ‘inner’ hardware/glass from the 06 door, should not be a problem.
BBTennessee
1947 and Older Ford Trucks
Jun 10, 2016 04:30 PM
Vadis
British Columbia
May 7, 2014 12:04 AM
abe
WTB - Parts & other
Nov 8, 2013 04:16 PM
richsoucie
May 11, 2007 06:52 PM
David
Aug 18, 2003 12:08 AM
