Sponsored by: Real Truck
99 7.3 4x4 not working
Old Dec 21, 2019 | 09:59 PM
Aaron Ellsworth's Avatar
Aaron Ellsworth
Iv got a 99 lariat powerstroke auto trans, I know this has probably been discussed a lot but I can’t find what’s specifically going on with mine, I have no power to the 4wd selector switch on dash and my 4wd light does NOT come on when I turn the key to the ON position. I can manually ground my relays and the motor will switch the transfer case to 4x4 but I have no idea what position it is in because the light does not work. I have changed the bulbs behind the cluster, the relays, and also swapped in a parts number matching GEM module. Any help or advice to diagnose would be MUCH appreciated.
Old Dec 24, 2019 | 07:38 AM
blakeusa's Avatar
blakeusa
Did you check the fuses and relays under the hood by the brake booster.
ChrisAiosa
Feb 20, 2017 10:35 AM
hooziewhatsit
Oct 5, 2016 03:04 PM
mclaughlin16846
Feb 22, 2014 09:16 AM
Steve 99 150 4x4
1997 - 2003 F150
Aug 2, 2013 08:42 PM
chopperkell
Mar 19, 2007 12:53 PM
