Sponsored by: Real Truck
Pcm
Old Dec 21, 2019 | 01:18 AM
David Acosta's Avatar
David Acosta
Pcm
I have a 2004 ford f 350 4x4 diesel dually . I used the 4x4 ,then started having trouble with what I thought was the transmission. It was hard shifting and popping at times. Once I put it in to 3rd and the truck went in reverse. After putting a snap on tool scanner it said the pcm . I change the pcm and it seemed better for a little bit I drove it about 10 miles going only up to 30mph then it started doing the same thing. I was told I needed to have it flashed . Does anyone know if that would be the problem.?
Old Dec 21, 2019 | 09:06 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The scanner said that the PCM is bad? What exactly did it say? I've never seen that message.
Motohead911
Jun 8, 2019 05:45 PM
cgouldy
1997 - 2003 F150
May 10, 2013 05:25 AM
bcaughhorn
Jun 7, 2012 09:24 PM
CREECY Strokin It!
Apr 5, 2011 03:28 PM
