1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Rear window slider defroster not working.
Old 12-20-2019, 05:47 PM
DaleEO's Avatar
DaleEO
DaleEO is offline
Recently went to use the rear window defroster during a snow storm and the center section / slider of my rear window wasn’t working. Did some internet searching which led me to several posts here, and found a defroster tab repair kit “Dr. Defroster” in the F-150 section. Bought the kit, followed the directions, and it appears it’s all fixed now.
Center section of rear window/ powered slider defroster stopped working.
Main power for the drivers side comes in at two square connections on right. The power passes through conductive strips in the glass to the connections where I’m pointing for the center section.
Visually found separated connection.
Outside view of main power squares on the left, and the round center section power supply.
Center section power supply pick up points.
Repaired center section connection.
11.75 VDC while the repaired defroster is on. When the connection was broken the voltage was 13.85 VDC as there was no load through the defroster grid.
Old 11-15-2022, 09:56 AM
Bardo805's Avatar
Bardo805
Bardo805 is offline
1st Gear
I have recently experienced this. Can you tell me if you removed the entire center section connection or did you apply the epoxy just between the connection and glass while still attached.
Thanks,
krane operator
2004 - 2008 F150
31
04-26-2021 09:59 PM
Frisbeekev
12-16-2019 06:54 AM
hharris8
12-09-2016 03:30 PM
jprix
1997-2006 Expedition & Navigator
11-05-2014 02:50 PM
pidaster
08-18-2011 07:29 PM
Quick Reply: Rear window slider defroster not working.
