FORScan read
Old Dec 20, 2019 | 03:02 PM
uglypitbull's Avatar
uglypitbull
FORScan read
Anybody know what 1.$ means on the BARO reading? Cant find anything on this one.
I am reading a 2000 Excursion 7.3 with a new MAP sensor and new EBP sensor...not sure where BARO comes from. I have them all set to read psi
It looks like MAP and EBP are good....I am at 6000ft above sea level. No codes except for AIH (which I deleted)
This was Key On Engine Off
Old Dec 21, 2019 | 03:24 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Baro sensor is built into the PCM. No clue what that reading means. Maybe there is another PID for baro in Forscan?
What symptoms do you have? Any codes?
Old Dec 21, 2019 | 11:36 AM
uglypitbull
No symptoms and no codes.....just doing some checkups on my F250's and my Excursion. Looking for weak spots in order to make a maintenance list for spring when its not 20 degrees out.
I looked at the FORScan forums and another person had the same issue.....but there was no resolution. I'll look for another BARO option, but I dont think I saw one....I did notice a couple options for the other two.
Old Dec 21, 2019 | 12:27 PM
bwguardian's Avatar
bwguardian
I have the same thing going on and have another thread I've been trying to figure it out...
moonley
Nov 21, 2016 07:12 AM
Diesel 724
Jan 21, 2014 02:07 PM
SideWinder4.9l
Jul 30, 2011 08:29 PM
DBGrif91
Aug 14, 2009 04:00 PM
cookie88
Mar 20, 2005 10:52 PM
