I have a 79 F150 that we just rebuilt power steering gear box on - problem is, with front wheels off the ground , it turns great both ways . On the ground is a different story -works great turning right , feels like manual steering turning left !! Any suggestions ?!?!?
Bleed p/s the FORD way and it works every time!!!
1- Hook everything up
2- Fill with fluid
3- Jack up front of truck off of ground (Both front wheels)
4- Disconnect or Disable coil (So Truck CANNOT start)
5- Turn Steering wheel lock to lock about 5 to 10 times 6- Top off Fluid 7- Repeat Step 5 8- Repeat Step 6 (top off fluid) 9- Crank engine over (Ignition Disabled) and turn steering lock to lock 5 to 10 times 10- Repeat Step 6 (top off fluid) 11- Repeat Step 9 12- Repeat Step 6 (top off fluid) 13- Enable Ignition 14- Start Truck and turn Lock to Lock 5-10 times 15- Turn off Truck 16- Repeat Step 6 (top off fluid) 17- Repeat Step 14 18- Repeat Step 15 19- Repeat Step 6 (top off fluid) 20- Let Truck Down off of Jacks or jack Stands 21- Repeat Step 14 22- Steering should work just fine, have all the air bled out and have a quiet pump to boot!!!
Several people on here have stated that even with this method it may take 2 or more attempts.
Luckily ours was one that took only one. It did puke fluid a time or two though. Be ready for it. (rags and more rags)
Thank you !! WOW - I’ve done this now about 8 times -still not working -belches fluid when turned right, still no p/s to the left !! I’m beginning to think I flubbed up inside the gearbox while replacing seals -
What was the original reason for rebuilding it? Was it for the same issue? I agree with above that they can be a pain to bleed. If bleeding does not work I'd say there's a valving issue inside the gearbox.
well, Rockauto sent WRONG part , now want me to pay half of return shipping ?!?!?!? Ordered from their DAMN website !! This thing isn’t light !! NEVER AGAIN !! Will NEVER trust them again !! Too much work, WAY TOO MUCH HASSLE - GUYS, find it somewhere else !!
