Freaking starter issues 2000 F250
Old Dec 18, 2019 | 09:27 AM
BLUEMAX65's Avatar
BLUEMAX65
Originally Posted by sunuvabug
PM just sent
Just sent you a PM back.
Old Dec 18, 2019 | 09:42 AM
Dan V's Avatar
Dan V
There has been a little chatter about changing the nose on a 6.7 starter and using that.
Old Dec 18, 2019 | 09:46 AM
Walleye Hunter's Avatar
Walleye Hunter
The ‘denso’ from autoparts is NOT the same as the one from CNC Fab.
Get the real denso starter and never buy another starter. Rebuild it yourself forever. Mine needed new contacts ($30 and 10 minutes) after 180k miles and is over 280k Miles now. Eventually it will need bearings and someday the motor may need replaced. All easy to DIY.
Meanwhile, it spins the engine faster and draws less amps than the other options for our trucks.
Ive put lots of these in and mine is the only one that needed service (10yrs later).
A drop of blue Loctite on the starter bolts is a good idea.
It looks like the solenoid case for that genuine Denso is a part of the that large casting there, whatever you would call it.
Old Dec 18, 2019 | 10:14 AM
SkySkiJason's Avatar
SkySkiJason
It is allegedly less powerful than a 7.3 starter.
Yes. The guts drop out with (3) screws so you can replace that part easily if it ever needs it.
After 180k Miles on my Denso, the contacts inside there needed replaced. $30 in parts and 10min job.
Old Dec 18, 2019 | 10:21 AM
SkySkiJason
Larry stocks all the DENSO parts you’d ever need and is a great guy to talk to.
Automotive Duty Starter Parts LarryB's
Old Dec 20, 2019 | 08:14 AM
Glowplugger's Avatar
Glowplugger
Well guess what guys? My teeth are still there, but they're ground down 1/4 inch!
Old Dec 20, 2019 | 10:36 AM
bwguardian's Avatar
bwguardian
Just as I suspected...
Old Dec 20, 2019 | 10:57 AM
MoBill122's Avatar
MoBill122
Papa Smurf
There's a video out there that shows how to change without pulling tranny all the way out. He just slid it back enough to get to bolts, rolled the engine over wrenching on front pulley, so he could get to each bolt as he turned motor over.
Cold time of year to be crawling under one, if you don't have a garage.
Old Dec 20, 2019 | 11:23 AM
AllaboutMPG's Avatar
AllaboutMPG
I may be wrong but don't think ground teeth on a fly wheel are the end of the world. If you get a good starter that is engaging properly that flywheel should still work.
Old Dec 20, 2019 | 11:25 AM
bwguardian's Avatar
bwguardian
That center tooth is almost all the way through...
Old Dec 20, 2019 | 11:52 AM
AllaboutMPG
yeah, hard to tell from pictures. Still will probably get him going for a while. At least until he's ready to tackle the fly wheel on his own terms
Old Dec 20, 2019 | 12:58 PM
SkySkiJason
The good news is, that only happens to (4) places on the flywheel.
The bad bad news is that is the (4) places the engine always stops at...
You need a new flexplate.
Old Feb 2, 2020 | 08:17 PM
  #28
bdpotts's Avatar
bdpotts
i know i'm over a month late to this thread, but i thought i cold add my .02$ as well. so i've been dealing with a grinding starter over the last year or so.. sometimes it grabs and cranks with little problem when others it takes a minute for the teeth to really grab. a few weeks ago it got to the point where i put in a reman'ed starter and within a couple of days, had the problem again but even worse. had to rotate the flywheel by had for 'clean teeth' and eventually the truck would start... anyhow, one morning i couldn't even get the truck started. realized it wasn't the starter, it was the lack of teeth to grab. so i picked up a new flywheel from RA and a authentic dense starter from the shop up in defiance, ohio and O.M.G. my truck starts so buttery smooth it's ridiculous. i can't believe how easy it starts and how clean it sounds while doing it. all those OEM starters just seem to squeal and grind and struggle when i think about it.. i've never pulled the trans, but i opted to leave my xfer case connected and after shaft and plate removal, just manhandled the trans/xfer case and it wasn't a big deal. stoked to have a running daily driver again.. working on posting a couple initial photos for ya.. cheers all.
Old Feb 2, 2020 | 08:30 PM
  #29
Glowplugger
I'm so sorry I didn't update this thread. New flexplate fixed it, and the old one had a huge crack in it where it bolts up too so it was a blessing in disguise!
Old Feb 3, 2020 | 06:03 AM
  #30
SkySkiJason
I love a happy ending!!!
Thanks for the update guys.
