auto shifter pointer
Old Dec 17, 2019 | 07:49 AM
hello113's Avatar
hello113
what are you people using for a shifter pointer? for a 65 f100 auto have the pointer on the column just need the plastic part that goes on the outside of the column also it is hooked to a c4 tranny
thanks mike
Old Dec 17, 2019 | 07:54 AM
Benny123's Avatar
Benny123
I have the same setup in my 65. Hopefully you have a truck lever for your c4, otherwise the indicator wont match the gear. As far as part number, Im sure ND will chime in.
Old Dec 17, 2019 | 10:07 AM
TA455HO's Avatar
TA455HO
Lead Gopher
From 1965 - 1972 the pointer was part of the gear shift lever socket or "bowl" as you can see in this picture. In 1973 they went to the bowl and separate plastic pointer.
Just the pointer is available from places like Dennis Carpenter.
https://www.dennis-carpenter.com/en/...icator-pointer
Read the second post here for the ND lowdown.
https://www.ford-trucks.com/forums/1...ft-socket.html
Chad
axidjw
Jun 28, 2017 07:05 PM
MikeS29
Aug 14, 2010 06:40 AM
IZZYAZ
Aug 18, 2009 08:29 AM
rmalottwtes30
Mar 19, 2008 08:10 PM
RustyTrustyF150
Nov 26, 2007 12:36 PM
