Trucks having problems
Old Dec 16, 2019 | 07:08 PM
Hunter Plathan's Avatar
Hunter Plathan
Hey guys I own a 2001 f350 7.3 truck is just rolling over 370,000km bone stock. Has been running good and strong but then three days ago I went to merge onto the highway and got up to speed and the truck lost engine power and started running very rough and shaking allot and an engine light came on. I tuned it on and then off and the light was gone and It was running normally so I drove it home and started looking into tranny problems. Then today I went for a drive and it happens again so i turned it on and off and it was fine again so I drove it home when I was going up the hill to my house it lost engine power again and shut off. I turned it back on and it was running fine again
Old Dec 16, 2019 | 07:23 PM
Walleye Hunter's Avatar
Walleye Hunter
How's your oil and fuel levels? Tinnerman nut on the back of the IPR and tight?
Old Dec 16, 2019 | 07:57 PM
Hunter Plathan
fuel is at half tank oil is good
Old Dec 16, 2019 | 08:10 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Check this and check the main wiring harness to 42 pin connector over the driver side valve cover. Sometimes the wires will rub through the coating and cause an intermittent problem like you are having.
Old Dec 17, 2019 | 01:40 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Inside the fuel tank there are 2 screens that can get clogged with debris. This starves the engine of fuel under heavy acceleration. A quick test for this condition is to disconnect the fuel line from the rear of the pump and blow shop air back thru to the tank. That blows the gunk off the screens. Remove the fuel cap first so the pressure has somewhere to go. If that clears off the screens it will run properly under heavy acceleration until the screens get clogged again. Look into Hutch and Harpoon mods to cure that problem forever.
Old Dec 17, 2019 | 07:36 AM
unleashd's Avatar
unleashd
Very similar to what I had experienced earlier this year. Check for water intrusion into the IDM. Here's a picture reference to the location of the IDM.
Old Dec 17, 2019 | 07:50 AM
HD Rider's Avatar
HD Rider
Check codes.
My guess is 1316.
You probably have a loose Under Valve Cover Harness (UVCH). Look up the 50 cent mod.
Old Dec 17, 2019 | 08:45 AM
SkySkiJason's Avatar
SkySkiJason
The stored DTC’s will help narrow it down.
Those symptoms mimic a dying IDM. (Key off, restart, problem solved - loose UVCH won’t do that consistently)
Old Dec 17, 2019 | 08:51 AM
arcticatdan's Avatar
arcticatdan
Mine has done that twice. It turned out to be the Cam position sensor both times.
DieselBeast01
Jan 17, 2023 12:43 PM
ghig1967
Dec 28, 2009 06:54 PM
Isletom
Dec 11, 2008 06:49 PM
Kizziah
Aug 5, 2008 12:37 AM
tigerdave
Sep 8, 2006 05:32 PM
