rear end sagging
Old Oct 11, 2003 | 03:21 PM
F0rdF0rever's Avatar
F0rdF0rever
rear end sagging
Scince the day I bought my truck, about a 2 months ago, the rear drivers side has been lower than the passenger side. Not just a little bit lower, but significantly lower. Atleast three or four inches. I changed all the shocks, so that cant be the problem. Could it be the leaf? Any ideas on this would be much appreciated, as always.
Old Oct 11, 2003 | 09:34 PM
Bolliger's Avatar
Bolliger
I have a 99 PSD and mine has been like that for several years and nobody has been able to tell me why. Maybe this thread will give us some answers.
B
Old Oct 12, 2003 | 07:14 AM
Quadzilla's Avatar
Quadzilla
I don't have an answer for you, but I do have a suggestion. I'd get under the truck, and start comparing measurements between the two sides. I'd check to see if the box is mounted the same on both sides, and whether there might be a spring issue on the right side. Somewhere along the line, you'll find the difference between the two sides, and will then be able to go about rectifying the problem.
Good luck.
Old Oct 12, 2003 | 07:38 AM
F0rdF0rever
Thanks Quadzilla. That was my plan for this morning. Im get under there and start comparing. Ill let you know what I find.
Old Oct 13, 2003 | 07:43 PM
Alamo PSD's Avatar
Alamo PSD
I had a sag problem in the front. Called Ford.They asked what the spring code was. Told to return the next day and they would replace the front springs. Took'm less than 2 hours.
You may have the same problem going in the rear.
Old Oct 13, 2003 | 08:16 PM
F0rdF0rever
My truck doesnt have springs. Its a 95 350 leafs front and rear.
Old Oct 13, 2003 | 08:50 PM
Ggg6's Avatar
Ggg6
Your "leafs" are leaf springs. If you have a crack in one of the l. rear leafs you lose that springs effect on the spring pack so the spring pack as a whole will be weaker.
Old Oct 14, 2003 | 07:00 PM
F0rdF0rever
Ok. Ive checked my undercarrige with a white glove and found nothing out of place. No broken leafs, shocks, or anything. Any other ideas? I cant stand to see my truck like this. Maybe I will post some pictures and you guys could take a look at it..
Old Oct 14, 2003 | 07:16 PM
Bolliger's Avatar
Bolliger
Ditto. It's sad to look at but nobody can see anything wrong.(Including me) What's next?
B
Old Oct 14, 2003 | 08:03 PM
F0rdF0rever
I dont know whats next. Think I may replace the leaf just for the hell of it..
Old Oct 14, 2003 | 08:49 PM
Alamo PSD's Avatar
Alamo PSD
Don't replace parts until you figure whats going on. Why waste the money? On level ground measure the height off ground to the center of each wheel well. Then compare the findings. You could also measure the frame to axle distance on each side and compare results. I've found measuring the body to be most tell tale. If you have any more than 3/4" (Ford tolerance), you'll definately notice it. If the numbers are out, the a trip to the Ford dealer is in store. Show them the findings too. Good luck
Old Oct 15, 2003 | 07:27 PM
F0rdF0rever
I was inspecting the rear end once again and found something off. The drivers side rear tire looked a little low. So I dug out the preasure gauge and it read only 20 psi. 45 pounds lower than it should have been. Odd because I just had the tires put on three weeks ago at my local sears. Now im wondering if its leaking or the mechanics didnt inflant the tire correctly. Well, problem solved. Thanks again everyones advice..
Old Oct 15, 2003 | 10:57 PM
FoMoCo136's Avatar
FoMoCo136
If you want to check the rear springs you will have to measure the from eye to eye. Springs that are defective will lose there arch. If the measurement between the eyes (where the bolts go through on each end) are different the truck will sag. This means the springs have lost their arch and the one with the longest measurement will be the one worn. You may need to replace both as the new spring will be fresh and have even more arch than the one that is apperently not worn.
Old Dec 4, 2003 | 03:09 PM
Renegadesrun's Avatar
Renegadesrun
Would have been funnier if you had replaced the leaf first.
danray35e
1983 - 2012 Ranger & B-Series
Nov 1, 2009 09:13 PM
crushtheogre
Dec 30, 2008 09:53 PM
cactus224
Nov 19, 2007 12:52 AM
timrec
Aug 9, 2007 11:10 PM
peppermintfatty
Apr 19, 2001 09:04 PM
