A simple question on coolant.
Old Dec 3, 2003 | 07:55 AM
StanleyZ's Avatar
StanleyZ
I tried this eariler but didn't get an answer so I'm rephrasing the question.
If I add the appropriate amount of FW16 can I use a regular off the shelf coolant in my 01 Turbo diesel 7.3L? If not, why not?
Thanks
Old Dec 3, 2003 | 10:26 AM
emtabmm's Avatar
emtabmm
yes...green coolant....
Old Dec 3, 2003 | 10:34 AM
SMB's Avatar
SMB
From dieselmanns site
"Use only a low-silicate ethylene glycol-based coolant. Ford does not recommend using propylene glycol coolants in any of their vehicles." and "2002 model year trucks use any of the above if your truck came filled with green coolant. If it came from the factory with yellow coolant, only use Motorcraft Premium Gold Antifreeze or Zerex G05 (gold bottle). These coolants do not require SCA/DCA. Do not use extended life coolants (ELC) as they can cause water pump seal and injector sleeve deterioration."
So yes, as long as its a low silicate ethylene glycol based coolant.
-Shawn
Old Dec 4, 2003 | 04:26 PM
StanleyZ's Avatar
StanleyZ
OK guys, thanks. Got my SCA strips today and tested that bad boy and it was well in the green. I'm not gonna worry about coolant for 15K miles. Now I'm gonna put up a post about exhaust brakes and see what aI get.
