Future Transmission issues????
This article: https://www.cartechbooks.com/techtips/autotransfluid states specifically that " Valvoline’s own “product data sheet” (the data sheet produced for every motor oil and ATF giving its specifications, which can be found on the petroleum company’s website) says that this ATF is recommended for GM vehicles, (which use Dexron III), and Ford products (using Mercon) and does not claim this fluid is recommended for any Chrysler product, much less GM products using Dexron VI or Fords requiring Mercon LV."
So how fast should I dump this junk and replace with the proper fluid? Looks like it's been in there for at least 30,000 km (20,000 miles) and it hasn't given me any problems - especially while towing - but again, if it's NOT recommended...it shouldn't be in there!
Anyone else use this stuff?
Had any problems?
Go to the manufacturer website instead of some 8 year old article.
Click on the PI sheet and it will tell you exactly what it is compatible with. Mercon LV is listed.
It will be just fine.
That old article is typical of someone who knows just enough to be dangerous; fooling himself and others into thinking they know it all, when they don't. He only looks are part of the topic and not all of it. Also does not appear to understand the Magnuson/Moss warranty act as well.
We are only taking Valvoline's word for it?
Just playing the devil's advocate here...and MY truck is just one year older than this article.
It's good ATF.
It's good ATF.
Don't fear Maxlife ATF; it is a well made, fully formulated product and can be used in LV applications without concern.
These kind of reports just make me wonder what is the other guy's issue...and why he would write something like that, if this is a decent product.
There are many applications where using something "similar" is of no consequence, but there are also some where you need the exact product or demise will ensue.
CVT trannies, for example, are extremely sensitive to the FM (friction modifier) chemical sorcery to operate properly and avoid untimely demise.
Other trannies seem to run on just about anything and survive decently.
Older trannies that use stuff like Ford "Type F" have a whole different FM requirement as well.
LV is a low viscosity variant of the other general ATFs such as the old Dexron III(h), Mercon, Mercon V. They all share similar properties other than the vis itself. The older ATFs such as those referred to now as Dex/Merc, or D3/M, or such similar stuff, all had a starting vis of around 7.3 cSt, but they sheared down quickly, often well below 6.0 cSt. When GM came up with Dex VI, and Ford came up with LV, these are more shear-stable ATFs that have similar FM and lubricant properties, but have a base-stock that is more robust and won't degrade as quickly. Hence, technically, anything that has a vis rating below 7.x cannot be formally licensed for Mercon V, because it's too "thin". However, Mercon V will degrade over time and drop below 6.0 cSt, where LV will drop far it's viscosity less, and they will end up with very similar viscosity.
There are two reasonable ways you can make an ATF selection:
1) use a fluid that is spec'd by the OEM and is formally licensed for that application (Such as anything that is "LV" compliant and has been tested/approved by Ford)
2) use a fluid which is approved not by the OEM, but by the fluid maker/marketer (Such as Maxlife ATF for the LV application, as stated by Valvoline)
I have always been amused that while some folks (not specifically the OP here, but just in general) worry about every last detail of some products, they completely ignore others which get a "pass" without any question. For example, Amsoil, Royal Purple, Red Line and other super-premium syns are not licensed for their ATF applications, but we pretty much never hear anyone bitch about that ... but when Maxlife ATF is not licensed, it catches everyone's eye. Beauty may be in the eye of the beholder, but sometimes I think people only have one good eye ...
The other topic one has to understand is the warranty issue; that of the Magnuson/Moss Warranty Act. (Check the FTC website and read up on it).
Warranty coverage is more about protecting the seller, but does do some things for the buyer.
