Rollover Accident DTC Codes Galore
My main question is does anybody have a sense looking at all these codes if there's one place I can start looking for some simple fix like a loose connector. I inspected behind the steering wheel and behind the E-brake as I've seen described in other posts. Also, does anybody know where ABS Module A is located?
Symptoms:
Steering wheel audio/menu controls non responsive but do illuminate
Turn signals non responsive via stalk but do work via hazards button
Windshield wipers and wash don't work except for max speed does activate via stalk
Hi Beams don't illuminate via stalk
DTCs:
Module: Transmission Control Module
Code: U0146 - Lost Communication With Serial Data Gateway A
Module: Powertrain Control Module
Code: P1934 - Vehicle Speed Signal
Code: P1637 - CAN Link ECM/ABS Control Module Circuit/Network
Code: U0121 - Lost Communication With Anti-Lock Brake System (ABS) Control Module A
Code: U0151 - Lost Communication With Restraints Control Module
Code: U0212 - Lost Communication With Steering Column Control Module
Module: Accessory Protocol Interface Module
Code: U0452 - Invalid Data Received From Restraints Control Module
Module: Body Control Module
Module: Front Controls Interface Module
Module: Trailer Brake Control Module
Module: Instrument Panel Control Module
Module: Global Positioning System Module
Code: U0140 - Lost Communication With Body Control Module
Code: U0422 - Invalid Data Received From Body Control Module
Anyway, they fixed it by disconnecting and reconnecting everything when taking it apart and reassembling it. I would do that yourself to see if you can get the dash stuff to work yourself. There is a connector at the rear of the frame that causes tons of problems even on non damaged trucks.
Find out who bodyshops in your area send their vehicles to (upholstry shop most likely) that redoes the airbags. You can get take out seats off Ebay maybe cheaper, let them plug them in.
I did 2 low mile F150s and almost did a cab and chassis. So I have some knowledge, but I would check into resetting the airbag light before plugging in seats with new airbags. I would ask around.
Does anybody have a diagram that shows where all the control modules are located? I'm curious about the ABS and Airbag Modules in particular.
Thanks
I would look for obvious stuff and take it in. You may chase your tail to save a few hundred dollars.
The guy that did mine does a lot of these aluminum fords for Municipalities and Construction companies.
Your other issues (high-beams, turn signal and steering wheel switch) would seem to point to issues with the turn signal switch and/or wiring in that general vicinity inside the steering column. Maybe those were damaged when the side airbags blew?
