Canking fuel pressure
Old Dec 20, 2019 | 02:35 PM
knottyrope's Avatar
knottyrope
i plug mine in to a light post that is switched inside the house
30 minutes plugged in makes a big difference on startup when 20 f out for me, you might need 45 minutes or more
Old Dec 21, 2019 | 09:31 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
These have I think a 1000W heater stock. I found that two or three hours plugged in will get my oil temp to around 100F when it is about 30F outside...so warm I can crank and start without glow plug relay hooked up. My 300SD has a 400W or so, takes about four hours to make a good difference.
Anyway, I would try it and see if that helps your truck start. -9F is pretty chilly and I doubt my truck could start in that as the engine is so beat, I have only tried it to low 20s and it started then. Knotty has a great thread for cleaning your battery posts of invisible corrosion, checking for resistance, cleaning grounds to block, etc Helped me diagnose my flooded F150 for slow crank.
Old Dec 21, 2019 | 07:05 PM
867.309's Avatar
867.309
This thread needs a link to the online diagnostic manual but it seems to have changed. Another thread needs a link too, for the diagnostic port. I looked at diesel stop, that's right isn't it? Did it change or is it me?
Old Dec 21, 2019 | 08:55 PM
Hit Man X's Avatar
Hit Man X
Ping me with your number, I can take a photo from my EVTM of the diagnostic port pin out.
Old Dec 25, 2019 | 10:04 PM
dlm7649's Avatar
dlm7649
I'm thinking about replacing the cam position sensor. Is there a diagnostic procedure to identify a bad cam position sensor?
Old Dec 26, 2019 | 07:48 AM
Jarrett Campbell's Avatar
Jarrett Campbell
It starts working when you replace it? lol just kidding
If you have a bad cps, you would see no movement on the tach while cranking.
Old Dec 26, 2019 | 10:26 AM
dlm7649's Avatar
dlm7649
Thanks
Thanks, that is helpful although I am not sure what to try next. Any suggestions?
Old Feb 15, 2020 | 06:36 PM
dlm7649's Avatar
dlm7649
I've been out of pocket - Broken leg. I'll be back in business in a couple of weeks so will need to get back to the truck. I thought the '94 1/2 did not have an electric fuel pump, but was looking at the fuse block and noticed that there is a fuel pump relay. Should this be an in tank or in line pump.
Is there a Bluetooth ODB scanner that will work on an ODB and an ODB2 vehicle. I have a cable adapter that will allow an ODB2 to plug into an ODB connector.
Thanks, Doyle
Old Feb 16, 2020 | 10:21 AM
BuddyBarnes's Avatar
BuddyBarnes
94.5 7.3l does not have e-fuel unless someone has removed mechanical and put in e-fuel as I did. No pump in tank.
Old Feb 17, 2020 | 08:06 AM
knottyrope's Avatar
knottyrope
scanner to monitor your engine
Amazon Amazon
Torque Pro
https://play.google.com/store/apps/d...g.prowl.torque
Use the communication in the profile
SAE J1850-PWM
make sure you add in Ford PIDs
https://play.google.com/store/apps/d...ch.CarGaugePro
people like it cause it will pull codes, buzz test and CCT
Old Feb 17, 2020 | 02:45 PM
dlm7649's Avatar
dlm7649
Scanner
The ad seems to say that the vehicle needs to be OBD2 compliment. I think I will get one if only for my other vehicles. However, will I get useful data from my ODB (1) ‘94 1/2 using my ODB to ODB2 adapter cable?
Old Feb 17, 2020 | 03:40 PM
BuddyBarnes
You have a obd2 connector under the glove box. If your computer has been re flashed it will work. . I use AE
Old Feb 17, 2020 | 03:46 PM
  #28
knottyrope's Avatar
knottyrope
I use that VGATE adapter in my 95 F350 and works in my 2009 Tacoma and have used in a 2015 Pilot and a bunch of others.
MN_Andy
Feb 24, 2017 12:00 AM
Shawn Paris
Aug 2, 2016 10:56 PM
shrek_47
Jan 26, 2015 09:09 PM
DJdemon6696
27
Dec 2, 2007 04:43 PM
okaw
Oct 12, 2006 11:11 AM
