Is there a way to load original firmware? I tried loading from a new APIM and now it won’t boot.
When you say original I think embedded and VERY difficult to add, delete or modify. When you do a firmware it is different from just doing a routine updat. Also it does not port.
if you can go in at the machine code level and you probably can embedded software is generally machine code or at least it was my day and you can break in those I’ve done it back before I retired in 2000.
edit: it’s a complete reflash of firmware i believe
I’ll wager that thread is what caused the problem to begin with. Sounds like the OP downloaded and tried to install the firmware updates. At least that’s the impression I get.
