Intermitent belt chirp
Old Dec 14, 2019 | 08:04 PM
Homerunking2394's Avatar
Homerunking2394
I have had a belt squeak that sounds like it hits a certain spot as it goes around and chirps as if someone increase and decreases the volume of the chirp....i put dish soap on the belt and it immediately got quiet. Then after a minute it got very loud as if something was going to explode. Belt was replaced 30k miles ago and looks good. Where should i start with replacing parts? Idler pulley has no play but makes a squeak noise if spun by hand as well as ac compressor.
Old Dec 14, 2019 | 11:45 PM
Colorado350's Avatar
Colorado350
Try taking a piece of hose (2’), with truck running put one end to your ear and carefully listen to each component. You’ll be able to isolate where the chirp is coming from rather than throwing parts at it. Sometimes you just need to let a component get worse before you can isolate the problem. Try taking the belt off and rotating each part separately.
Old Dec 14, 2019 | 11:58 PM
Homerunking2394
id like to bypass the ac compressor since it doesnt work and scraps when turned by hand with belt off...water pump has no play and spins smoothly
Old Dec 15, 2019 | 01:28 AM
FinnishStroker's Avatar
FinnishStroker
I just installed AC delete pulley in my van.
Old Dec 15, 2019 | 01:54 AM
Homerunking2394
do you have a link or part #?
Troobly
Dec 28, 2018 10:35 PM
stefanwest
1983 - 2012 Ranger & B-Series
Oct 25, 2014 07:38 PM
Mike Hannahs
Oct 2, 2013 09:33 AM
ManfredVonRichtofen
1978 - 1996 Big Bronco
21
Aug 4, 2012 08:37 PM
dougielx
Aerostar
Sep 19, 2008 06:10 PM
