Running wires
Old Dec 16, 2019 | 10:50 AM
Barbero's Avatar
Barbero
I used a sharpie razor to make a small X inside and out. I did tape the wire to a long thin screw driver to pull it thru the X's. This was 18 months and 15,000 miles ago. No leaks, or any problems. I also covered the wire in flexible conduit since it ran above and behind the motor along the firewall to the fuse box.
Old Dec 16, 2024 | 05:34 PM
Djohnson7's Avatar
Djohnson7
1st Gear
Would anybody happen to know what the wires are for going through the grommet?
Old Dec 17, 2024 | 04:50 AM
speakerfritz's Avatar
speakerfritz
I tried to use that dimple on the steering bulk head grommet…too much friction and it was really to small.
needed
-1/8 host to use on a boost controller
-power and ground for methonal injection controller
-banks bus wire bundle
-sae 10 amp red/black power cable
wound up find a clear on both sides area and used an offset drill with a step bit and put a 1/2 hole thru the firewall and put a grommet on it.
work fine and if I ever need to make it bigger easy with the step drill.
you can also run a pretty large size wire bundle thru the rubber plug at the floor drain. Plug is about 1” in size.
beeser
Sep 30, 2013 06:28 PM
maltesecross
6.7L Power Stroke Diesel
Jan 13, 2013 09:34 PM
Dave HM
6.2L V8
Oct 30, 2012 08:24 PM
460 FORD MAN
22
Aug 10, 2012 04:34 PM
drizzie27
Mar 28, 2012 06:08 PM
