Intermittent Crank, No Start
Old Dec 13, 2019 | 03:50 PM
Grannygear's Avatar
Grannygear
The week of Thanksgiving I went to go somewhere in my 2005 6.0 F-350 and it cranked, but would not start. I was out
of town the first week of December, but upon my return the truck started and ran. This past Monday I ran some errands stopping at several different places and it started up every time. Day before yesterday I got in it and it cranked, but would it start. I got in it today to run my TorquePro and it cranked up. I took screen shots of the gauges while it was running and with the key on, engine off. Does anybody see anything with my gauges that might point me in the right direction of diagnosing and repairing my no start problem? Should I add any additional gauges that would help with the diagnosis?
Old Dec 13, 2019 | 07:50 PM
bismic's Avatar
bismic
Check for codes. IMO ForScan Lite is a better code reader than Torque Pro, but maybe you can pull something useful.
Otherwise, we need to see the cranking data when it doesn't start!
Old Dec 13, 2019 | 08:15 PM
Grannygear's Avatar
Grannygear
Attached are the fault codes off of the TorquePro. I will search on how to save data during cranking. It started up twice today. I notice that the fuel pressure gauge on TorquePro shows 0 pressure. Not sure how that can be if the engine is running. Thanks for your response.
Old Dec 13, 2019 | 08:23 PM
bismic's Avatar
bismic
The 6.0L doesn't have a fuel pressure sensor
Old Dec 13, 2019 | 08:25 PM
bismic's Avatar
bismic
P0480 can be an issue w/ the fan clutch wiring or the clutch itself. That can cause a no-start. Seems like so many electrical issues are intermittent.
Check the fan clutch connector and wiring very carefully.
Old Dec 16, 2019 | 08:23 AM
glafond's Avatar
glafond
had the same type of intermittent issue.
sometimes would not start.
when it did start, it ran fine, but occasionally i noticed an extremely brief (not even a second) loss of power.
went on for weeks.
then one day it just would not start, at all.
FICM module failed.
Old Dec 20, 2019 | 10:06 PM
Grannygear's Avatar
Grannygear
Thanks for the responses. I read a lot of posts on this issue, but the thing I read was a sticky written by bismic. The check list included "sufficient fuel level". I noticed my fuel gauge was at 1/8 of a tank and my fuel range was 80 miles. I got to truck to start and drove it the gas station where I filled it up. That was last week. I have driven or started the truck every day since then.It has started every time. I am now wondering if my low fuel level was causing my problem. I will update this post with any further developments. Thanks again.
Old Dec 20, 2019 | 11:13 PM
xcrsp440's Avatar
xcrsp440
If it happens again try to also find the cranking rpm and FICM sync values. Good luck.
20046.0250va
Jul 12, 2017 05:59 PM
mlbaldwin77
Jan 6, 2015 06:13 PM
joe.d
Jun 1, 2011 11:28 PM
250FordTruck
Electrical Systems/Wiring
Mar 8, 2011 04:44 PM
tobacco farmer
Dec 18, 2009 07:53 PM
