Back up lights
Old Dec 12, 2019 | 10:08 PM
Frank79's Avatar
Frank79
Back up lights
Is there a way to have your back up lights turn on when you unlock your truck? The parking lights turn on but not the back up.
Old Dec 13, 2019 | 07:17 PM
D3thM3tal's Avatar
D3thM3tal
That is one of the biggest annoyances with GM vehicles. The reverse lights are for exactly that, backing up and shouldn't be used for anything else.
Too many times have I waited for someone to back out of a parking spot only to find it is someone who unlocked or locked their vehicle and waiting is a waste of time.
Old Dec 13, 2019 | 07:31 PM
Frank79's Avatar
Frank79
it’s only time LOL..
Old Dec 13, 2019 | 07:41 PM
D3thM3tal's Avatar
D3thM3tal
They are meant for backing up, what next, blinkers to notify people what door just opened?
Old Dec 13, 2019 | 08:25 PM
NorEasterMA's Avatar
NorEasterMA
Short answer is no. Are you wanting them to turn on so you have additional light in the rear of the truck? If so, there are other ways. What is the trim level of your truck? Do you have a backup camera and power tailgate lock? If so, it is likely that the courtesy light (trailer hook up light) that mounts next to the tailgate handle will be plug and play. My truck is a '17 XLT Premium and the wiring for this light was existing in the tailgate harness, truck side. Added the wires tailgate side, added a few Bolt LED's and bingo, very bright lighting when I unlock the truck or open the doors. And it dims to off just like the mirror puddle lamps do.
Old Dec 15, 2019 | 08:59 AM
dzdiggin'dude's Avatar
dzdiggin'dude
NorEaster can you go a little more into detail on your light set up? Tried searching Trailer Hook Up Lights and it just brought me back here. Thanks.
Old Dec 15, 2019 | 12:47 PM
Frank79's Avatar
Frank79
I want them to turn on so at night time I have more illumination. I have the XLT trim.
I do have a camera and power tail gate.
Old Dec 15, 2019 | 08:46 PM
NorEasterMA
Then this mod might be perfect for you. Start with this thread, refer to post 23.
https://www.ford-trucks.com/forums/1...-up-light.html
It details what you need to look for to confirm you truck is set up for the lights. You can then either go OEM with a new tailgate handle molding and harness or just add some lights as I did. I'll include some pictures of my setup below. What I did initially was add the two pins in the tailgate plug for the light power and ground, and then add the two wires to the plug and wire them to the two bolt LED's that I mounted in the handle bezel. But due to not having the correct pins to add to the plug, it wasnt a reliable connection so I ultimately bought the tailgate harness that had the additional wires and plug for this light, which I then wired my lights into. I got all the info initially from the above linked thread.
Size:  946.1 KBName:  photo799.jpg
Size:  876.7 KBName:  photo840.jpg
Size:  1.03 MBName:  photo872.jpg
Size:  958.5 KBName:  photo860.jpg
micheal1619
Jan 11, 2016 07:06 PM
Wrenchgear
2009 - 2014 F150
Aug 11, 2015 01:03 AM
KC8QVO
6.7L Power Stroke Diesel
Aug 2, 2011 05:43 AM
Moyerboy
1997 - 2003 F150
May 6, 2007 04:06 PM
